Jeff Wolt, Looking for 4mm clockwise cable/shaft
Tags: None
You want a 4mm stub with a 150 cable? Doubt it ...would be so thin it would not hold on the stub walls. I can do 130 cable.
I might be able to do 150 but I have to remove a layer of the 150 winding. Then it could be silver brazed. -
The stub I have now fits a square end .150 cable. The cable just slips in there.
The start of the shaft it is 0.209"/ 5.31mm diameter and 17mm long, the rest of it is 4mm diameter and the entire shaft is 62mm/2.441" long.
I don't suppose you have .150 cable with a square end for clockwise rotation do you?Comment
Ok sweet cheers Jeff. Had a look on your site. Ill just mod the stringers for a 3/16 stub grab some of the ones u got on there once I know the lengths.Comment
