Why do some people solder a capacitor to their esc ?
  • lucozader
    • May 2009
    • 144
    also what size capacitor is good ?
    In simple terms - particularly when using long power wires (over 8" total), adding caps helps protect the ESC from ripple current which can cause ESC failure. The "capacity" of the caps depends. You want a cap with more voltage than your ESC maximum (like 35 volts for a 6S controller), good for 105*C, and equal to or greater than 500 uF. Sometimes two or more are added.
    • kjohnsiii
      • Oct 2010
      • 116
      Does anyone have pics on what the aditional cap looks like. I am considering adding one to my esc and not shure how it should be mounted.
      Thanks
      • Dangerous_Toys
        Hiding from the Ole Lady!
        • Apr 2010
        • 2250
        You can also purchase an already assembled cap board. They get soldered on to your battery wires on your esc.
        ? WHAT RULES?
        • Alexgar
          • Aug 2009
          • 3534
          i put this on an 80 amp i recieved and 2 of thr 3 cap had pulled off, chep and effective
          Welcome to RadioShack's official website. Search and shop for electronics, gaming devices, powerbanks, audio products and business traveling gear.
          • kjohnsiii
            • Oct 2010
            • 116
            Do these reduce heat?
            • m4a1usr
              Fast Electric Addict
              • 2038
              Thanks
              Lots of different ways to install extra caps. Here is one method from Schulze.
              John
              Change is the one Constant
              • Make-a-Wake
                FE Rules!
                • 5557
                I added these two 1000uf 35v caps to the 3 existing 1000uf 35v's on my T180. Caps went down in temp significantly.
                • graill
                  Retired
                  • 389
                  For those big jobs.
                  • ManuelW
                    • Oct 2010
                    • 756
                    Concerning capacitors:
                    The rule "a lot helps a lot" is true and the reason for additional capacitors was already explained. Therefore I just want to add a hint: Put the caps as close to the controller as possible, this will increase performance. If the cables between capacitors and controller are too long, there won't be a positive effect.
                    Best regards,
                    Manuel
                    • bwells
                      • Jan 2009
                      • 842
                      Would 3 caps farther away be the same as 2 close, i.e., adding wire to get to the caps? Thanks
                      • kjohnsiii
                        • Oct 2010
                        • 116
                        Thanks for the pics guys.
