Ive been using the conversion tables on OSE for speed estimates of my boats for some time now, and they work well. However, there isnt anything for twin setups. Any advice? I was thinking maybe lower the prop slip on the regular table, but I wouldnt know how much...
Speed predictions for twin drive boats
Tags: None
Well a twin setup won't get you that much more speed, just more pickup and raw power correct? Depending on how fast your boat is going... The difference could be anywhere from a couple MPH (top speed) to something big like 10 mph. Whats the size of you boat (and setup)? -
Im going to more than likely try lots of different combos before Im done, but right now its a 30" cat with twin 1520/1600kv on 6s with cr x447sComment
Ok, and what is your estimated speed?
You should just spend 50 bucks on a GPS... make this alot easier....Comment
Its a new build...not even finished yet. If it were I would just use my GPS but I am refering to using the table (or other calculators) as a tool to set up a boat, not estimate speed of a boat that I am already running. Youre right, I would just use my GPS for that.Comment
Useing my highly scientific and calibrated "eye" I can say that with the same hull the speed is a little higher on twins, not significant but still noticable.
Big bonus is the acceleration, sound and .......cool factor ! plus the ability to drive home when a shaft leaves the boat
A single setup costs less than a twin but the way I speced it I now have two well overpowered therefore understressed drivetrains and have good reliability with low temps and a bit more speed than a single.
I wanted twins because I had to have one, did I mention how great they sound and the acceleration ??
Do twins if you must, like me, but for for a SAW setup ............ask Jay.See it....find the photos.....sketch it it....build it........with woodComment
10% really? I'm at work now playing around with the calculations, I was going to suggest a greater decrease, more like 25% slippage.... I wonder why you found it to be so low? Maybe its dependent on each motor setup and not a uniform comparison on all motors? I'm a bit perplexed... 10% seems rather low. I'll have to play around.Comment
With twins your driving two props. Double the surface area.If all of your wishes are granted, many of your dreams will be destroyed!Comment
A couple of years ago - mid 2008 someone posted a formula for figuring out speed on twin drives! Search the older entries in either this section or the building section. I wrote it down have to look for it!We did it with a Bang!
Cats Are Where It's At!Comment
What kind of motors are you running and what efficiancy % did you enter?Comment
OK Keith - back on 02/22/2008 one of our members ... aka 10guage, posted a statistical formula if you search for it - it should come up, read the whole thread! When applied to my Twin Jolly it came within 2 mph of actual
The thread is titled "Formula for Calculating Speed" !
Hope this helps!We did it with a Bang!
Hope this helps!Comment
