titian 29
  • MARKBRENNAN
    • 395
    titian 29
    How good are the aeromarine titian29s I just bought one. What kind of prop should i use.
    • 9488
    The T29 is a sweet boat
    and your prop depends on setup
    • Chilli
      • Jan 2008
      • 3070
      What motor are you running? What part of Md are you from??
      Mike Chirillo
      www.capitolrcmodelboats.com
        The Titan 21 (its real name) is a great boat for 4S power. The hull is pretty much limited to 50 mph because it has a lot of lift. That lift allows it to run very well with spec power, giving speeds in the high 30s/low 40s. In fact I think that spec power is probably the "best" overall power for this hull.
        It can certainly take a lot more power. In the bad old days - five years ago - we ran them with 18 NiMH cells and thought 45 mph was screaming. Today guys put hot 4S and 6S setups in them and go fast...but blow overs are a fact of life at high speeds.
        What setup do you have - motor, cells, esc? We can't tell you the prop without that info.
        • MARKBRENNAN
          • 395
          I have not gotten the boat yet but planning to put a turngy 120 esc and a supervee b36-56 brushless motor.
          • knpc
            • 566
            I loved my Titan with an SV motor. I tried putting a faster motor in it, but like Fluid said the hull wants to take flight after fifty mph. I went back to the SV motor after too many jaw dropping blowovers.
            Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine Conquest
            • MARKBRENNAN
              • 395
              What size prop are you running.
              • weil0127
                • Dec 2009
                • 164
                How do you tape down the hatch with that cowl??
                www.namba20.com
