what ESC for Pspec hydro
  • JimClark
    • 5907
    going to build a p spec hydro and am looking at options for a ESC. Setup will be run with a BJ-26 motor. I have the matching proboat ESc and also a hacker 70 (probably not high enough amp's). Looking for options as I am concerned that the proboat is just physically too big.
    Jim
    Billy Graham
  • JMSCARD
    • Mar 2010
    • 3444
    Jim
    a turnigy marine 120 is on the swap shop now... those are a great esc and I believe a little smaller then a swordfish 120... but on that end steves swordfishes are down to $69 both should be a little smaller then the bj esc... ideally the old barracuda would work well if you need room... but its a tall order finding one... are hydra 120's too big?
    • JimClark
      • 5907
      Not sure on the hydra 120
      Billy Graham
      • teach
        • Jun 2008
        • 509
        What hull Mr. Clark?
        • JimClark
          • 5907
          it is top secret my lips are sealed
          all I can say is it is a hydro kit (Shovelnose/roundnose) that will be eventually be availabel
          Billy Graham
          • BakedMopar
            No Mo Slipah
            • Sep 2009
            • 1679
            Campbell 30".............I'm waiting for that one to come out. I've been saving up for the release. I use the aquastar 120 ( swordfish 120 ) and I dont like the lagged throttle response. They hold up fine though. Never had any luck with the seaking 120 eighter. I like the UL-1 esc's in my spec rigger. I've had some pulls of over 80 amps and keeps on ticking. I love the linear throttle response too.
            • JimClark
              • 5907
              Yup a Campbell 30 kit.
              It's gonna be nice for sure even better than the Miss K
              Jim
              Billy Graham
              • Flying Scotsman
                Fast Electric Adict!
                • Jun 2007
                • 5190
                Jim, the Turnigy 180 Amp esc will be the ticket and they are not expensive.
                The Black Douglas...Scotland rules
                • JimClark
                  • 5907
                  A 180 seems overkill for a spec BJ26 on 4s doesn't it?
                  Billy Graham
                  • raptor347
                    • Jul 2007
                    • 1089
                    Jim,
                    I have to agree. If you have space, the turnigy 180 is a great ESC. Overkill is good when it comes to ESC's. Throttle is very smooth.
                    Brian "Snowman" Buaas
                    Team Castle Creations
                    NAMBA FE Chairman
                    • JimClark
                      • 5907
                      doubt there is room for the 180 as this hull is a Karelsen much thinner than an older shovelnose. Is the throttle curve on the 120 as smooth as the 180?
                      Billy Graham
                      • Doug Smock
                        Moderator
                        • 5272
                        Those controls will work fine until you join the ranks of the stator bakers.
                        MODEL BOAT RACER
                        IMPBA President
                        IMPBA 19887L CD
                        NAMBA 1169
                          I use the Castle ICE100 in my LSH boat. It works great, doesn't take up a lot of space, is easy to program with the link and provides excellent data logging without the hassle of all those extra wires and sensors. So far I have not needed any cooling, although I may install a small fan. It handles spikes up to 150 amps - not that difficult to get with some spec setups. It does need a Pistix, Steven carries (or did carry) all you need.
                          • teach
                            • Jun 2008
                            • 509
                            If you have thespace the BJ speedo is bullet proof. Although I moved over to a CC 60 amp high voltage.....cause I won it in a raffle.
                            • properchopper
                              rcgoatbuild@snotmail.com
                              • 6968
                              I've had really good luck AND performance with the UL-1 speedys as well - they don't run hot, are waterproof, and two that I've been running for a long time now were originally cap-puffed, so I added external caps and they run exceptionally well with the UL-1 motor and BJ 1500 KV motor. I just substituted a Turnigy 120 set at 15 deg advance to the UL-1 powered FE 30 to compare to the UL-1 speedy but won't be able to test this weekend 'cause them pesky straightline guys are taking over the lake [ and some boat-laden hairy FE go-faster dude from NorCal will be shacking up at the Chalet d'Properchopper this weekend].
                              Hey Doug, my shrink says I'm a "joiner", how do I join the stator baker ranks ; Oh wait... never mind ...
