Anyone used these drives on there 33" MiniMystic?
While building what I thought might be a problem turned out to be a real issue.
I mounted the drive itself on the sponson transom as low as it could go without grinding into the bottom but when mounting the rear pads the drive had too much negative and there is no way to get it out without recessing the rear pads through the bottom as the adjustment is collapsed all the way. Don't want to cut the holes in hull but it seems the only answer. You could maybe get the drive
1/16" lower on the transom but we need at least 3/16 just to get to neutral drive angles.
Anyone else have suggestions or have same problem?
Video running,
Picture showing drive angle with too much negative.
Video running,
