leaking stuffing tube ?
  • lucozader
    • May 2009
    • 144
    i have a stuffing tube with flex cable and teflon lining
    i greased it as well
    but the water keeps coming in
    what am i doing wrong ?
  • marko500
    • Aug 2008
    • 861
    Put a piece of piece of water tube or heat shrink over the end of the stuffing tube and a little section of the flex shaft inside the hull, it acts as a seal. Also some guys use a piece of shrink tube over the nose of strut and stuffing tube. Maybe someone can explain it better then me or post a pic.
    Mark
    • bigwaveohs
      • May 2009
      • 535
      Vacuum Caps
      Go to an auto parts store and get an assortment of vacuum caps...get the size that fits the stuffing tube, (e.g. 1/4") and punch a hole (e.g.3/16") in the end and slide it over the flex shaft and stuffing tube...
      I let the dogs out...
      • forescott
        Hopelessly Addicted to RC
        • 2686
        grease between the teflon and brass tube as well. Water can seep up between the two.
        • m4a1usr
          Fast Electric Addict
          • 2038
          Yeah the silicone tubing or heat shrink works great for me. And if it doesnt seal it 100% put a small sponge under the flex/ST. That will catch the left over!
          John
          Change is the one Constant
