hello I am going to be getting a df29 hull and would like to know what people think about hardware on this hull? I am using a leopard 4074 on 4s and want a stinger style system..and starting with no trim tabs or fins? I was eyeing the mono harware system here on ose store that is for mono's for 97 bucks but as well have the full hardware from a sv27 I am unsure what to use, as I have it all but the drive hardware help pleeeeeaaassse?
delta force 29 hardware issues plz?
The speedmaster hardware is what I have on mine it turns on a dime no turn fins or tabs needed. Strut 1/8th of an inch from the bottom of the boat and rudder in between the right side and the prop hope this helps.Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx. -
The speedmaster hardware is top notch! Under a hundred bucks for a stinger, rudder, flex shaft, drive dog, prop nut, teflon and stuffing tube.... I think its well worth the $$$ and the quality is much better than that of the sv hardware.Comment
The speedmaster hardware will work great. You will want turn fins.If all of your wishes are granted, many of your dreams will be destroyed!Comment
