problems.
  • steve-b
    • Mar 2010
    • 245
    problems.
    Hey guys,
    The last few times i have run my boat, it has died out in the water.
    Its a jae 21, im running a neu 1515 1y with a SK 120A ESC with a cap board, the batteries are Turnigy 2s 40c in series. I am usually running with a x445, or smilier size/pitch.
    I'm thinking that it is the LVC ????
    Any thoughts?
    I have disconnected the bec from the ESC and am going to run with a external pack, this wont happen until Saturday, I'm hoping to get some feedback before then
    Thanks.
    Steve.
  • Diegoboy
    • Mar 2007
    • 7244
    Does it suddenly stop or slow down to a stop?
    Does the steering still function with no throttle or no control at all?
    Does the throttle/steering return when you get it back to shore or not?
    Has it run well before on the setup you stated or did this start on first run?
    • steve-b
      • Mar 2010
      • 245
      1) It just stops.
      2) No control at all.
      3) It returns after about 15 mins.
      4) It was the first run on this setup.
      • jac4412
        FE Addict
        • Jun 2010
        • 425
        I've had this problem in my brushless setup on my shockwave rs... It was a bad soldering job on my BEC and connections, I'd get a couple seconds of run then would die.. How long will the boat run before it dies??
        JAC4412 RC
        • steve-b
          • Mar 2010
          • 245
          It will run about 2 mins.
          • Doby
            KANADA RULES!
            • 7280
            Thermal cutoff perhaps?
            Grand River Marine Modellers
            • steve-b
              • Mar 2010
              • 245
              "Thermal cutoff"????
              • JMSCARD
                • Mar 2010
                • 3444
                I agree... 1515 1y on a 120amp esc is pushing it.... I would prop down to a x440 or x442 and see if the problem persists.... a x445 seems pretty ampy.... usually folks run a 150amp plus esc for the 1515 1y 2200kv motors...
                • steve-b
                  • Mar 2010
                  • 245
                  Is it that the 1515 1y pulls alot of amps?
                  UL1 setup will turn a x445 all day.
                    The 1515/1y is a LOT more potent that the little UL-1 motor. Even the UL-1 will pull 90-100 amps with that prop (datalogged), the Neu is probably pulling 140-150 amps. Your ESC is thermalling - getting too hot and shutting itself down before it melts. If you want to run that motor, get a 180 amp minimum ESC.
                    • JMSCARD
                      • Mar 2010
                      • 3444
                      YES... I would be running a x440 or x442.... a x445 is alot of prop like i say for a 120 amp esc... the 1515 is very high 4s amp motor...
                      • BakedMopar
                        No Mo Slipah
                        • Sep 2009
                        • 1679
                        I'll put money your hitting the LVC. Also a 120 with that motor is way too small. I ran a 1415 1y in my JAE for a couple runs and would hit the cutoff unless set at 3.0v with fresh 40-50c 5000 turnigys in 1p.
                        • JMSCARD
                          • Mar 2010
                          • 3444
                          Remember also that a ul-1 is a lower kv motor then the 1515 1y... Higher kv with same voltage = more amps...
                          • steve-b
                            • Mar 2010
                            • 245
                            I ordered a 200amp ESC, will see what happens???
                            Im running out of weather here in Ontario.
