just curious if anyone has done this at all and if the esc let the magic smoke out.Even though it just says 4s on the manual
anyone run 5s on ul-1 esc
In theory yes if the specs hold true,as its rated up to 20v.
specs
Length: 3.25" (83mm)
Width: 1.5" (38mm)
Height: 0.3125" (17mm)
Weight: 3.8oz (109g)
Wire Gauge: 14 gauge
Max Output Power: 720 watts
On-Resistance: 0.003 ohms
Low Voltage Cutoff: 11.63V
Stutter Bump Voltage: 12V
Thermal Cutoff: 230 degrees F (110 degrees C)
Operating Frequency: 8KHz
BEC: 5.2V/2A
Timing Angle: 10 degrees
Battery Connectors: Male Deans Ultra Plug Connectors (2)
Motor Connectors: 4mm Gold-Plated Bullet Connectors (3)
Input Voltage: 12-14 NiMh 4 Cell Lipo (8-20V inout w/o BEC)
Output Current: 60A Continuous Maximum
72A Surge Maximum -
Yes. but I would not recomend it.If all of your wishes are granted, many of your dreams will be destroyed!Comment
.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
