Help on Hydra 240 LV warranty
  • nova68
    • Jul 2008
    • 151
    I have two Hydra 240 LV, one the caps are leaking with one run on them and the ether one was repaired by Castle Creations first run went two feet when it blew up big time I am running a NEU 1515/1Y on 4S2P 5000 mah, no BEC, battery pack 5 cell 1600 mah with a Octura M 445/2. I called Castle Creations Repair and they put me to Technical Support which told they would not warranty one because they only fix them one time a the ether one is my fault, not correct batteries size. I can use a little help with setup. So they will not warranty them at all, NOT HAPPY about that. One boat is a Delta Force 33" with a Neu 1521/1.5D on two batteries 4 cell each 5000mah / 4S2P total 10000mah with the Hydra 240 LV with a Octura 447/3 prop that is the one that blew up Next boat Delta Force 29" Neu 1515/1Y Hydra 240 LV 4S2P 10000mah with a Octura M 445 prop these 240 LV is the one with bad caps.
  • JMSCARD
    • Mar 2010
    • 3444
    are you saying you ran two 2500 mah packs in 2p for 5000mah or two 5000mah packs in 2p for 10000mah... because if it was two 2500mah packs with a low C rating that is a problem....
    • johnf
      • Dec 2009
      • 1078
      What boat is this setup in?
      Catching Air!
      • JMSCARD
        • Mar 2010
        • 3444
        that 45" inch sniper in his avatar? lol...JK.
        • nova68
          • Jul 2008
          • 151
          Help on hydra 240 LV
          Delta Force 33" NEU 1521/1.5D Hydra 240 LV 4S2P 10000 mah Octura 447/3 next boat Delta Force NEU 1515/1Y Hydra 240 LV 4S2P 10000 mah Octura M 445/2
          • LiPo Power
            DJI Drone Advanced Pilot
            • May 2009
            • 3186
            How old is your 1521/1.5d?
            Canada
            • nova68
              • Jul 2008
              • 151
              Hydra 240 LV
              January 15 2010 from ose if you need the date on the box I have to get it.
              • LiPo Power
                • May 2009
                • 3186
                Was your motor and connectors very hot?
                Canada
                • nova68
                  • Jul 2008
                  • 151
                  Hydra 240 LV
                  Temp about 98 degrees on motor and ESC
                  • Steven Vaccaro
                    • 8721
                    How did they determine that the setup was incorrect and what did they tell you was the correct setup?
                    • LiPo Power
                      • May 2009
                      • 3186
                      Hmm, sounds like you are one of the unlucky people with the blown hydra....
                      You can try to replace caps on the one that is poping up. Use larger capacity caps and replace the old ones. That should fix the problem.
                      When it comes to Castle warranty I am not sure of how to help you...
                      Maybe someone alse...
                      Robert
                      Canada
                      • nova68
                        • Jul 2008
                        • 151
                        They would not give me a setup, but that setup is online at there sit, he told me not enough mah my mah is 10000 on 4 cell, and I have bad batteries, now I am waiting for a call from Castle. if they ever call me.
                        • 6S HYDRO
                          • 1320
                          Bad batteries, hahahahahaa - bad esc
                          • domwilson
                            Moderator
                            • 4408
                            Try sending a PM to Joe Ford. He is a member of this board.
                            Government Moto:
                            • nova68
                              • Jul 2008
                              • 151
                              domwilson who is JOE FORD you said he is a member of this board how can that help ?
