PWM rate
  • keithbradley
    • 3663
    PWM rate
    Im running a Leopard 4082 (4 pole motor) ona castle ICE160. Anyone know what the correct PWM rate is?
    www.keithbradleyboats.com
  • Raydee
    • May 2007
    • 1603
    Start at 8khz and see how it runs. I run my Ice 200's at 8khz and they seem to run great.
    Team Liquid Dash
    • keithbradley
      • 3663
      Thanks. I was running it at 12khz and noticed my other escs are factory set at 8khz. I am having some issues where my motor will cog or shutter sometimes when you hit the throttle after getting some water in the boat this morning and wanted to make sure I couldnt fix it with programming but I tried other settings and it doesnt seem to help. Im thinking maybe a wet pistix may be the culprit. This is my first time using a pistix, but I would imagine this might be the effect it could have if it wasnt working properly.
      • Raydee
        • May 2007
        • 1603
        My guess is the wet Pistix is the problem. What radio are you using? I use the DX3R with my Ice 200's and calibrate the throttle on the radio so I don't have to use a Pistix.
        Team Liquid Dash
