Cooling
  • Woodz
    • 40
    ive just made some notchs in the barbs and the most resistance i in the esc?
    • Jeff Wohlt
      • Jan 2008
      • 2716
      I now get my silicone tubing from the fish shop. Larger ID and cheaper. Better water flow.
      www.rcraceboat.com
      jwohlt5362@yahoo.com
      • m4a1usr
        Fast Electric Addict
        • 2038
        Amen Jeff. Good stuff. Great inside dimension and like you said. Cheap. PetSmart has been my water cooling tubing supplier for the last couple of years. Its not 100% silicone but its got enough to work with the temps we see.
        John
        Change is the one Constant
        • SweetAccord
          Speed Passion
          • Oct 2007
          • 1302
          So is it better to use larger ID tubing than the rudder's diameter and lose the water pressure or use smaller ID to keep the water pressure flowing to the ESC and motor?
          • Krowbar69
            • Sep 2010
            • 237
            I don't think you'd be losing a lot of pressure, unless it's a huge difference.You might lose some pressure, but there's more volume of water passing through i bet.
            • Simon.O.
              • Oct 2007
              • 1521
              There is a lot of info here about cooling and a lot of different opinions too.
              If you need cooling then 1 pickup should be fine. Run it to the esc and then to the motor.
              Cooling circuit flow is another BIG area of discussion.
              I go for a mild flow that makes a strong trickle at the outlet. Imo if the outlet has a jet of water then you are causing a lot of drag for no additional cooling benefit.
              Another approach is to have no cooling at all. My smaller OR powered hulls run this way.
              Also my 34" Cat with OR motors that runs low 50's has no water cooling at all. I will admit that it is a 2 minute wonder as that is all the packs can give it.
              There is a lot to read about water cooling and then you can make an educated decission as to how to attack your setup.
              fwiw I have had hulls with multiple pickups and up to 4 independant circuits.
              Not any more. I now spec my fun hulls to not need WC but my semi-saw hulls have WC but shiate still smokes
