Want to know Best glue/epoxy for velcro on fiberglass
  • Karfrik
    • Jun 2009
    • 1177
    Im tired of changing the velcro every now and then.If i`m gonna glue it,wanna use the best method available.LMk what you use...thanks...Al
  • ozboater
    • May 2007
    • 415
    in my experience with both poly resin and z-poxy, neither work... i m contenplating a couple of the 3 racing axial carbon trays mounted to the floor of the hull..
    also curious as to what others are doing for side / side battery mounting...
    • Karfrik
      • Jun 2009
      • 1177
      Hi,....gave those a thought but they won`t fit,very tight comparment.So lets see what else we get from our fellow forum members.......thanks,Al
      • westbeach
        OSE Rocks!
        • 951
        Firstly I have never mounted velcro directly onto f/g. I have some mil-spec double sided tape that I have, I should test to see how well it sticks on f/g. This stuff ain't cheap either. But if it works it works, right?!
        HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
        • Karfrik
          • Jun 2009
          • 1177
          So how you stick/strap your packs into the hull?.....
          • westbeach
            OSE Rocks!
            • 951
            I have rails in my DF Cyber Storm and I made a battery tray out of plexi. Battery sticks on the velcro stuck on the Plexi.
            • westbeach
              OSE Rocks!
              • 951
              With that said, I am finally finishing my HPR build, and I don't have trays for the batteries, so I might try out the HD double sided tape theory.
              • Karfrik
                • Jun 2009
                • 1177
                Ok,so you are glueing the plexi tray into the hull then?....
                • electric
                  • May 2008
                  • 1744
                  I am using super glue on the velcro strips to the fiberglass and they never come up. Not sure if I could rip them off if I wanted to...
                  • westbeach
                    OSE Rocks!
                    • 951
                    Nope, held down with brackets and screws. Here's some pics http://forums.offshoreelectrics.com/...ad.php?t=16957
                    • steve-b
                      • Mar 2010
                      • 245
                      I use 3M double sided tape. It is awesome stuff. I once used it to attach the rear sponsons to the hull of a rigger, i ruined both sponsons trying to get them off.
                      Never tried it on FG but i imagine it would do the job.
                      Steve.
                      • T.S.Davis
                        • 6220
                        I use marine goop. Holds up for ages if you glue to a clean hull.
                        Noisy person
                        • Karfrik
                          • Jun 2009
                          • 1177
                          OK!!...Getting there...now i have options!!!...if anything else keep it coming..thanks guys,....Al
                          • driftah
                            • 760
                            use ca glue(cyanoacrylate er somethin) as long as its flat it worked awesome for me,or maybe shoo goo on a roughed up surface.
