Stock boat comes with 2270kv motor & 120amp esc with bec, Will it take 4s lipos ok for short dash runs of max 10 seconds & could it go any higher than 4s considering the short maximum run time.Thanks.
Genesis Cat
I run my factory Genesis on 2x2s=4s always and my runs are usaully like five mins or so long,,should be shorter but once she's going i just cant stop,,motors temp usauly around 130, esc is around 100 and batts each are around 100. -
Just thought about it,,,i have recently drilled holes in the back of the motor plate to let the heat get out of the motor and juast got a new water pickup so i can have the one from the rudder go to the esc and the other go to the motor but havent installed it yet,,just to help cool things but i was tould my temps are ok now alittle high but ok...Comment
Hey Jabbo the prop is a TFL and the number on it is 435,,,it fits the stock stub shaft not the upgraded 3/16 stub,,,i measured it from tip to tip its 35mm i think or realy close...Comment
