forgot to put this on my last post but my 25"hor rocket has a watercolled motor and esc and they dont seem to get any water it uses a water pickup on the rudder???
watercooling issues
Take the line off the top of the rudder and blow through it. If you can't, there is a blockage somewhere. What's with the T fittings? The way you have it set up the water is blowing right past the motor and out the discharge! Get rid of those "T's"! Run from rudder through esc to motor, through motor and out! Period!Mini Cat Racing USA
www.minicatracingusa.com -
Water takes the easiest route so with that being said all the "t" connectors you have maybe part of your issue. Get rid of those connectors and run the water line to the esc 1st then to the motor or mount then motor. Just have cooling to the esc first. Take a small rat or round file and slightly enlarge the opening in the rudder. First step is to dump those connectors though. Take the cooling line off the top of the rudder and blow through it make sure you feel air coming threw the outlet.
HAHAHA SAILR YOU POSTED WHILE I WAS TYPING.Comment
Start by eliminating those "T" joints.
Route it as such: Pickup to ESC - ESC to Motor - Motor to outlet
Post a pic of the opening in the rudder blade please..."A quick temper will make a fool of you soon enough."
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Bruce Lee. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Comment
I don't know about me having a great mind, but thanks.
Originally posted by Woodzyh soz i posted wrong pictue it doesent have tht t connector now it goes just like u both said through the esc then motor and theres NO blockage in the rudder ???Comment
Try the T-pieces this way it looks like you dont have them flowing the right wayAttached FilesUL1- 1515 castle/neu / 240 swordfish
SV27- with UL1 running gear
33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2PComment
You don't need the T's at all! Get rid of them! Take off the tubing from the rudder and blow through it! Is it clear? I wouldn't booger up that rudder! Most likely the opening's fine. I have NEVER had to enlarge one.Mini Cat Racing USA
You never answered whether or not you can blow through the system? If not, then there is a blockage. If you can, then it should be working. Why do you say it's not working? Have you run the boat?Mini Cat Racing USA
