vvvIIvvv's HPR115
  • westbeach
    OSE Rocks!
    • 951
    vvvIIvvv's HPR115
    Liam, I started this thread so as not to muddy up Randy's Hpr115 thread build.
    You're running Neu 1521-1Y on 6S 5000Mah. The KV of the motor and the 6s should bring you to around 35,000 rpm/kv. I can't see why you can't get on plane. Have you played with the setting on the esc? Check your driveshaft, make sure there is no binding.
    HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
  • vvviivvv
    • May 2009
    • 1079
    Thanks for the thread... i set the esc's up as i was told to... the programming is in german... i might run it on Thursday and video it so people get a idea... i will try how it is currently set up them move the weight way forward...
    any 1 with a idea is appreciated.
    Uk SAW record holder
    • Gerwin Brommer
      • Dec 2008
      • 918
      Few good pics of the interior, , side-back-view, and back of the boat, might help ?
      • vvviivvv
        • May 2009
        • 1079
        here's how its set up... how far the drive is down etc... and btw is this the correct rotation of flex shaft for a prop spinning this way?
        • vvviivvv
          • May 2009
          • 1079
          hah ^ 10 seconds sooner -.-
          • Gerwin Brommer
            • Dec 2008
            • 918
            Rotation/prop is okay.
            Second pic : no space between drivedog-white washer, and the drive ??????
            4th pic : is that grease at the bearing, or has the alu tube widened ??
            • vvviivvv
              • May 2009
              • 1079
              no space there...
              grease on 4th pic
              • Gerwin Brommer
                • Dec 2008
                • 918
                Please leave some space between de drive and the drivedog !
                When running the boat, the flex will "shrink" under load.
                So they will pull the drivedog towards the motor = drivedog will rub against the drive =massive friction !!!!
                Where is the COG in your boat, measured from the transoms ?
                • vvviivvv
                  • May 2009
                  • 1079
                  cg umm it doesn't have one. i just guessed it as i never understood it...
                  • Gerwin Brommer
                    • Dec 2008
                    • 918
                    center of gravity.
                    Is the point where the boat is in balance.
                    With the lipos in the normal place, determine the balancepoint.
                    Put the boat on a table, let the back go over the edge of the table.
                    At the point where the boat starts to slide off the table : that's your cog.
                    Is that point somewhere in the 33-37 centimeter range, measured from the transoms ???
                    • RandyatBBY
                      • Sep 2007
                      • 3915
                      Try pushing the struts all the way up up. Instead of all the way down and making the boat run wet and harder to launch.
                      Randy
                      BBY Racing
                      • vvviivvv
                        • May 2009
                        • 1079
                        its right in the middle actually gerwin... 35cm from transom
                        randy, the boat creates a massive bow wave it needs pushing over the top if you get me... will lifting the drives achieve this?
                        and gerwin now i completely understand how to measure cg..
                        • vvviivvv
                          • May 2009
                          • 1079
                          i have a 1 - 2mm gap between now gerwin in the shaft...
                          • Gerwin Brommer
                            • Dec 2008
                            • 918
                            1mm is enough.
                            I just saw the other topic where I saw what props you are using...................
                            1.8 pitch !!!!!!!!!!!!!!!!!??????????????
                            The hpr06 is a catamaran, NOT a purposebuild SAW-rigger !!
                            please look for props like octura X4.. series !
                            • Flying Scotsman
                              Fast Electric Adict!
                              • Jun 2007
                              • 5190
                              If I was in your shoes I would change out the motors for a lower Kv and run 8S
                              Douggie
