Have some questions about this ESC:
I am thinking now that I should have waited until I had enough funds to order stuff from this side of the pond. This hobby is turning out to be almost epensive as owning and operating my full size cruiser. The definition of Boat seems to be abou the same for the scale verions as the grown up ones. . .
B.O.A.T. --- Bring Over Another Thousand.
Boat: "A hole in the water, lined with fiberglass that you throw money into."
- Is this ESC is the same as the Hifei 90 amp ESC?
- Is it pretty much plug and play on a 4s 2300kv set up or will it require parameter changes to run?
- If programming changes are neccessary will the Hifei program box work on the Aquastar? The Aquastar program box is currently on backorder and can't seem to locate another source besides HK.
