going to be running the 580l 1894 kv in the titan 29 and was wondering which mount will work, I have the one that excepts 380 to 540 motor mount but dose it work for the 580 as well? the feigao 580L:580 7L 1,894 RPM / Volt (3) is what i wanna run maybe it's too big?
580l motor mount
Tags: None
I used a Peter Zicha mount. You can find them in the product section. The bolt pattern is the same as a regular 540 mount but you will have to widen most as the diameter is bigger than the 540.If all of your wishes are granted, many of your dreams will be destroyed! -
going to be running the 580l 1894 kv in the titan 29 and was wondering which mount will work, I have the one that excepts 380 to 540 motor mount but dose it work for the 580 as well? the feigao 580L:580 7L 1,894 RPM / Volt (3) is what i wanna run maybe it's too big?Comment
Good work. I have a leapoard 5692 and I'm currently trying to figure out what mount I can use. The mounting holes on the leopard at 30mm apart. The biggest challenge is finding something to adapt that will allow the HUGE diameter of the motor+ jacket.Mini Cat Racing USA
