Damaged bearings in wire drive strut
  • Ronbo
    • 121
    Im having an issue with my bearings in my scale hydro, on .078 wire. I was told the strut is new, my bearings are new (bought a set of 4, flanged and non.)
    I managed to make it through a race day, but I damaged 4 bearings, 2 flanged and 2 non total, including 2 test sessions a week before. I was told that my prop was probably out of balance, but its a carbon prop that had been ran by one of our top racers. My robart balancer just wont do something so light..
    My motor runs really warm, about 120-130 , (feels more like 140 )on temp gauge, more so than the first run i did over a week ago.
    I did remove a washer the last test runs after the race, and it seemed to have gotten better. the bearings seemed fine. the washer wasnt perfect match, so could have cause a vibe?
    What am i to look for in setting up the drive dog, bearings, grease etc? right now, it feels pretty smooth. I use just thin film of grease in case the wire rubs the sides of the stuffing tube? I realize its hard to analyze not seeing the setup.
    What simple balancer (magnet?) could I buy to balance carbon and then metal props?
    Ron
    1/10th 2014 U-6 Oberto ,1999 U-6 Miss Madison, 1971 U-6 Miss Madison, 1976 U-6 Miss Madison Unlimited Hydros
  • JimClark
    • 5907
    Where did you get the bearings
    Billy Graham
    • Ronbo
      • 121
      Boca bearings, green seals.
      Ron
      • JimClark
        • 5907
        How bout pictures of our strut setup and where the bearings are located. Something sound's weird here. Are all 4 bearings in the strut?
        Also I assume this is a modern CT 1/10th what motor and prop?
        Billy Graham
        • teach
          • Jun 2008
          • 509
          I just went through the same thing with my LSH boat. 6 blown bearings in about a week and a half. Prop was balanced fine. I think my drive shaft was just to long (22") causing a weird vibration when I gave it full throttle with no load. It's just a theory though. Maybe it was just piss poor luck.
          • DPeterson
            • 842
            teach
            I just met this teach guy out at the Colorado Nats. I am not sure he has his bearings straight. So I would really think about what he has to say.
            Just kidding. It was great fun messing with teach and I believe he knows what is going on.
            Doug
            Doug Peterson
            IMPBA 19993
            www.badgerboaters.com
            • tharmer
              • 342
              I had the same problem. It turned out that the wire was not exactly aligned with the bearings. The side load trashed them. they were good bearings.
              So, make sure the stub shaft is exactly aligned with the two bearings with absolutely no side load. Then I suspect you'll be fine.
              -t
              • teach
                • Jun 2008
                • 509
                Originally posted by DPeterson
                teach
                Doug
                Hah! The wheels on the bus go round and round.
                • Ronbo
                  • 121
                  modern hull, 2 bearings in strut, 1 flanged 1 non flanged. Ive pushed the strut back up for setup reasons, as it was down fully to set up the hydro. Ill try to post pics later.
                  I have the drive dog against the bearing, but I want to pull it out a bit to leave a gap?
                  Ron
                  • JimClark
                    • 5907
                    leave a gap for sure
                    Billy Graham
                    • Ronbo
                      • 121
                      How much of a gap tho? .005 to .010" or so?
                      scorpion 3026-1900 on a graupner k45. Not sure what it will do on an octura
                      Ron
                      • AlanN
                        • Mar 2008
                        • 334
                        Wire drives are finicky. If the wire has a bit of a wobble will wear out the bearings. I used to loctite mine into the struts and a friend of mine would insert his loose. Mine seemed to last longer but was harder to replace. Everything must be very straight and clean on a wire drive. The c/f prop should not be an issue unless it is really torn up. I would leave only a very fine amount of space from the dog drive to the strut...maybe a few .001's. The more of a gap you have the more load on the wire and will bend the wire to cause more vibrations. Gave up running them due to the maintenance....cables are almost as good for performance but far better for maintenance and regular running.
                        • properchopper
                          • 6968
                          I've found that the rearmost flanged bearing had insufficient "shoulder" to stay aligned with the strut. Once worked loose, the resulting wobble caused havoc with it and the front bearing.I've discussed this with Mr. Wohlt and as a result the rear bearings in his subsequent (and my) strut (s) are now non-flanged. I have Red loctited the bearings in to keep them aligned and run minimum tolerance between the drivedog and strut. I have had trouble removing bearings to replace, and now have one strut in which the outer race is permanently stuck in the strut, and being stainless is impossible to drive out or dremel.
                          • AlanN
                            • Mar 2008
                            • 334
                            Tony,
                            try hitting the loctited area with some flame. I like to use a small butane torch. It's tough to get the right spot but when it does melt the bearings will come out easily.
                            • Steven Vaccaro
                              • 8720
                              Or try a good soldering iron.
