Esc for Leopard hobby 56x92??
  • forescott
    Hopelessly Addicted to RC
    • 2686
    I want to run the new leopard hobby 5692 1340kv motor on 6s. I'm looking for some suggestions on an esc that will power this combo. Will anything less than a 240 work?? Motor specs say 110 max amps??
  • Diesel6401
    Memento Vivere
    • 4204
    Yup Leopard spec sheet says 110 max. I would roll with a swordfish / Aquastar 240 or a Monster 2000. They should get the job done. Of course with that monster you will need to water-proof, water-cool and use a pistix. JMO.
    Are you using this motor in that df41 copy u just picked up
    - Diesel's Youtube
    - Diesel's Fleet
    • Diesel6401
      Memento Vivere
      • 4204
      You know I bet a good old T-180 will get the job done. It's got a 360 amp burst. If that motor max's at 110 it shouldnt run that much constant. I'd try a T-180, just make sure you disconnect the bec and run a rx pack.
      - Diesel's Youtube
      - Diesel's Fleet
      • forescott
        • 2686
        I was hoping to use the 180. It would save me some cash!
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3480
          I think you could get away with it. I've pulled some hard and heavy amps through them and no problems. JMO, but I would try it.
          • Diesel6401
            Memento Vivere
            • 4204
            Good you can be the "test" subject with the leopards lol.... I'm sure you'll be fine.
            - Diesel's Youtube
            - Diesel's Fleet
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3480
              I was considering this motor for a DF 41" copy... Curious how it performs and what it takes to spin it up.
              • forescott
                • 2686
                I will be using it in the same hull you have. The HK osprey.
                • FighterCat57
                  "The" Fighter Cat
                  • Apr 2010
                  • 3480
                  Cool!
                  • vasy
                    • Dec 2009
                    • 333
                    Same here, just in the middle of mounting it... how are you guys cooling it?
                    I can only think of aluminum tube wrapped around it while OSE comes up with water jacket.
                    • forescott
                      • 2686
                      I'm gonna wait for the jacket. Which esc are you using vasy??
                      • vasy
                        • Dec 2009
                        • 333
                        Will go with Turnigy 180 for now as it is all I have.
                        • sailr
                          • Nov 2007
                          • 6927
                          What kind of motor mount did you find?
                          Mini Cat Racing USA
                          www.minicatracingusa.com
                          • vasy
                            • Dec 2009
                            • 333
                            Take a piece of strong aluminum angle bracket and cut whatever fits the boat.
                            Should have the boat ready by next weekend.
                            • sailr
                              • Nov 2007
                              • 6927
                              So you use a wooden wedge under the aluminum to get the shaft angle?
                              Mini Cat Racing USA
