Apparition on 6s with typhoon 1800kv
  • Graeme
    • Jun 2010
    • 90
    Well took the Apparition out tonight with Turnigy typhoon 1800kv and six cell Lipo.
    I managed to get 52mph before the gps died on me.
    I did 4 WOT runs before bringing it in to check temps esc was 86 motor was 130.
    I tryed to get a video but the camera man didn't know how to work the camera.
    next time I will be sure to get a video and fully charged gps batteries.
    This motor is Awesome even on 4s its much faster than stock and stays cold 80 deg.
    Also it has way more torque and I would guess I get an extra 5+ minutes of run time.
    I was thinking of putting this motor in the red evo but now I am reconsidering as I think it would be a little much.
  • Graeme
    • Jun 2010
    • 90
    forgot to mention prop used 40mm X 1.4.
    I think I will try larger on 4s as the esc and motor were ran cool.
    • Jeff Wohlt
      • Jan 2008
      • 2716
      So you mention 6S in the header....will you be trying that?
      www.rcraceboat.com
      jwohlt5362@yahoo.com
      • Graeme
        • Jun 2010
        • 90
        I did try it on 6s I see the confusion I was not too clear in my explanation I will change it
        thanks.
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3480
          Cool! The outrunners seem to be the way to go!
          • Graeme
            • Jun 2010
            • 90
            Yeah I can't believe the torque difference and the sound they just sound mean.
            I will try to post a video soon.
            I think I am going to try one in the genesis cat when I get it.
            • Make-a-Wake
              FE Rules!
              • 5557
              I wonder if a 38mm prop would bring the temps down just a tad on the motor, and maybe even let it rev out a bit more...........may end up being as fast but cooler............????
              • Graeme
                • Jun 2010
                • 90
                on 4s it runs a sold 43mph and cool i think it will be a good reliable set up of 4s
                my gps is too heavy and causes a bad list so it's probably more like 45
                I definably need a smaller prop for running on 6s motor temp was 150 esc was 80.
                and something was smoking I am hoping it was just the 4mm bullet connects. I have larger ones on the way.
                anyway here is a video on 6s it flys
                • Graeme
                  • Jun 2010
                  • 90
                  the other thing I changed was timing from 11.25 deg to 15deg
                  not sure if that had an impact on the motor heat or not
                  • ray schrauwen
                    • 9475
                    Yes, it should be at 15 degrees.
                    Nortavlag Bulc
                    • Graeme
                      • Jun 2010
                      • 90
                      I wonder if I can break 60 with this set up will have to try a smaller prop and a smaller GPS.
                      • britscoot
                        • 656
                        I'm going to put that typhoon motor in my red evo!
                        will try it on 4s and work my way up!
                        Small prop also.
                        Wish me luck....hahaha
                        • FighterCat57
                          "The" Fighter Cat
                          • Apr 2010
                          • 3480
                          I'm not so sure. More like 55 I think.
                          Running T180 CC/Neu 2650Kv on 4s w/440 was 58mph (39k RPM) and had to go up to 8mm motor bullets. I melted the solder connections on the Castle 6.5mm bullets. Probably could have gotten 60 w/442 but kept breaking the drives... Too much RPM.
                          Depending on your lipo weight and I think the Typhoon is lighter... might get close to 60.
                          • Graeme
                            • Jun 2010
                            • 90
                            I think that with a small gps I could probably get there the one i am using weighs more than one of my lipo packs.
                            where does one buy a cheap light gps from ?
                            I am loving this set up I bought the typhoon for the surge flusher and never installed it before I sold it.
                            • FighterCat57
                              "The" Fighter Cat
                              • Apr 2010
                              • 3480
                              Look for a Forerunner 101-301 or Foretrex. Nice, small and simple. That's what I use. I'm still trying to get my Apparition to break 60 reliably...
