it isnt a dumb? The only way to learn is to ask. 6s2p would be 2 6s packs running in parrallel. Basically both pos. Battery leads go to the pos. Lead on the esc, and the same with the neg leads. So 2 6s packs at 4000 mah will give you 8000 mah total. Also when runnin 1p, to figure the batts available amperage you multiply the constant c rating with one hundreth the c rating. So, a 30c pack at 5000mah would put out 150 amps constant. With 2p, that mah number would double, but the discharge rate stays constant. Make sense?
