hardware recommendations
  • 08gtrking
    • 91
    I need help picking hardware for my 36 inch cat it going to be running 1090kv motor on 8s.thank you ahead of time.
  • sailr
    • Nov 2007
    • 6927
    Is that the new Leopard 5692? That's a LOT of motor for a 36" boat! I usually stick with Speedmaster hardware from OSE. The quality is outstanding and the prices are more than fair.
    Mini Cat Racing USA
    www.minicatracingusa.com
    • 08gtrking
      • 91
      It`s actually 38 but the extra two inchs are on the tip so i don`t think it matters and i picked that motor to go 65+mph what you think ? i was thinking this http://www.offshoreelectrics.com/pro...prod=ose-80085 but sence he is out of stock i think ill have to go with this
      • skellyo
        • Feb 2010
        • 592
        For my Aeromarine Sprint Cat (34"), it was recommended to buy a Speedmaster 3/16" XTD strut, round bottom. For the rudder, a Speedmaster .40 rudder with the proper setback to correspond to the XTD strut. I would imagine you don't want to go any smaller than that on a 38" cat and both of the items you linked are smaller.
        • 08gtrking
          • 91
          can anyone please point me to the right direction i don`t know anything about hardware i would really like double water pick up ruder that would be a plus.thank you in advance.
          • ozzie-crawl
            • Sep 2008
            • 2865
            not sure on how the rear of your hull is (extension or not)
            • 08gtrking
              • 91
              The tunnel is 31inchs and is inward and has 1and 1/2 inchs surface to put hardware on
              • ozzie-crawl
                • Sep 2008
                • 2865
                you could use one of these,for the rudder http://www.offshoreelectrics.com/pro...ckets+%26+More
                set back will depend on strut length, one of these should be okay (mono round bottom) http://www.offshoreelectrics.com/pro...d=ros-21-strut
                you could go the larger twin water pickup rudder and trim the length as well
