I dont usually post much here but i thought i might get some responce since there are heaps of people with different setups...
Im currently looking into some 10s setups.
I run a twin SGX-2 80-90 rigger with 1527/1ys also tried 1527/1.5ds
5s each motor, 40/160s for ESC's
It hammers. Initial props were the 1657's stock but now i run 1462 - 4.75inch cup and H30s with 5inch cup and its nuts.
My issue is that the rules in AUS might change and therefore my 5s each motor is not legal to run as its not a voltage of 37volts for 10s...
So im asking - who has run 2 motors of a single 10s pack?
Im looking at 1527's since thats what my motor mounts are made up for but i can make new ones to suit other diameter motors.
I need to be able to pull 60+ mm props to get the bum of the rigger out of the water. I can run smaller props but it goes better with larger ones cause thats what the boat was designed for. What ever i choose to setup the boat with it must make the 1500m oval (just short of the mile) At current my setup does make the distance without killing the cells. Nothing else gets warm, packs are 130-140 max, and im left with 35-40% in them at the end. Half mill and 5 laps. I need to park the boat after the race or things will burn. I have not attempted to do 6 laps. I know i could do it with what is left in the cells but there is no need. Unless i jump the start.
Thoughts people.
Cheers Dave
Thoughts people.
Cheers Dave
