New lipos
  • WrknItUp
    • Jun 2010
    • 338
    New lipos
    Im new to using lipos i just got my set today. 2- 2s1p 5000mah turnigy and 2- 3s1p 5000mah turnigy packs. Do i need to discharge them first or do i need to charge? Then afterward it says to cycle atleast ten times before trying to acheive maximum. Maximum what? Sorry new to these things right now im worried about the garage burning down lol.
    I believe it's my god-given right, To destroy everything in my sight. Cause it never gets dull, it never gets old. The only thing it gets is more bold. Drinkin', fightin', going to the game. In our world it's a way to stay sane. If you're asking me. To have it my way, I'd say that's One fine day. ---- The Offspring
  • Doby
    KANADA RULES!
    • 7280
    Just charge them...no need to cycle them.
    Grand River Marine Modellers
    • WrknItUp
      • Jun 2010
      • 338
      also 5000mah i can charge at 5.0amp right? or do i need a slow first charge?
      • LiPo Power
        DJI Drone Advanced Pilot
        • May 2009
        • 3186
        Just like Doby said, charge them at 5 Amp no problem, do not need to slow charge them.... That is old school with NiMh batss...
        You can use balancer at the same time if you like...
        Canada
        • WrknItUp
          • Jun 2010
          • 338
          Awesome thanks for the help. i think i can handle this. i hope the performance aspect was worth the wait!
            That means do not run at maximum discharge rates. Most pack makers recommend cycling the packs at low discharge rates several times before running WOT in the FE boat. OTOH most new FE boaters lack the patience to follow directions, so few do this. But since this recommendation is almost universal among the makers there is probably something to it....
            What is the downside of not cycling? One reliable test I am aware of showed that not cycling the cells made them produce full power sooner (fewer WOT cycles) but reduced the cells' life by ~35%. I cycle all my new packs 3-4 times at 2-4C before I put them in the boat - this only takes a few hours to do as I am set up to do it. I have yet to have a pack go bad in the 4 years I've been using LiPos, and I've set SAW records with my packs.
            • sailr
              • Nov 2007
              • 6927
              The discharge many times before maximum is an old Nickel Metal Hydride axiom! NO NEED TO DO THIS WITH LIPOS! Charge 'em and run 'em!
              Mini Cat Racing USA
              www.minicatracingusa.com
                There is a dichotomy in opinions regarding LiPo break-in, largely because the bulk of buyers are impatient and want to believe they can run their packs at full discharge right away. I trust the sources below (among many others). YMMV.
                One thing to note when reading opinions about break-in...how hard is the user pushing the pack? If he normally only discharges at 8C when flying or running a car, then his normal use is actually a "break-in". Bottom line - do what you want, but don't insist on an absolute answer.
                • sailr
                  • Nov 2007
                  • 6927
                  I don't know how old the Ezine article is but Violet's article is two years old. The newer nano packs, such as Hyperion G3's do NOT require cycling!
                  Mini Cat Racing USA
