Hi, gents; new member here.
I have some RC experience (nitro boats and planes), but I'm new to FE boats. I currently have a PB Shockwave 26, and it's been enjoyable to run, but the fun doesn't last very long, and I wish it was much faster. I estimate its top speed at somewhere in the neighborhood of 20 mph and run time is only about 5 min. I'm running a 6 cell 5000 mah NiMH batt, not Lipo on this boat. The X435 prop is the only part of the boat that isn't stock.
Anyway, I just bought an Aeromarine Popeye's .21 cat hull (29" L X 11" beam) and I have a Graupner GTX820 outboard without motor I'm mounting to it...
http://www.offshoreelectrics.com/pro...od=grp-2380-11
This outboard has the flex shaft in teflon tube drive system, not a gear driven lower, which should improve reliability and reduce resistance for better speed. Even though I could probably get more speed from an inboard setup, I just like the scale appearance and bolt-on simplicity of the outboard, without the need for a stuffing box and additional running hardware.
Anyway, to my questions...
If you were me, what motor, ESC, battery pack(s), and prop would you pick for this hull and outboard combination? Of course, I want to run Lipo batts in this boat. Obviously I want more speed than the Shockwave 26 delivers, but my priorities are the following (in this order):
1. Dependability/ longevity. I don't want any cheap parts or unreliable components I will have to replace anytime soon.
2. Reasonably good speed with reasonably good run time. By that, I mean I would be happy with at least 35 - 40 mph, and more than 5 min run time, preferably 10 min. I want impressive speed, but I'm not necessarily looking to get as much speed as possible at all cost. More speed is great as long as it doesn't come at a huge penalty in cost and run time. I would much rather have 10 min run time with a top speed of 40 mph than 5 min run time and 50 mph, for instance. I don't plan to race, just have fun.
3. HIGH QUALITY brushless motor and ESC. I'm willing to spend more if doing so buys quality, and I want to avoid as many parts made in China as possible for philosophical reasons (though I know I may have a hard time avoiding China - made parts in my radio, receiver, servo, and batts). At minimum, I don't want a motor made in China.
4. Cost. I don't want to go nuts, but I'm willing to spend more to get more of the above.
The motor mount screw spacing on the outboard appears to be 25mm, and the flex shaft coupler adapts to motors with 5mm shafts. Although the prop shaft is threaded for 4mm props, I have a 4mm to 3/16" prop shaft adapter, so I can use any prop for 3/16" shaft diameter.
Any explanations for your choices is much appreciated, as I don't know what to look for in the motor KV ratings, which motors are compatible with which ESCs and battery packs, amp ratings, etc. Like I said, I'm new to FE boat setups.
Thanks in advance for your help!
Ted
Ted
