Eagle tree systems
  • keithbradley
    • 3663
    Eagle tree systems
    Im not too familiar with the eagle tree systems, but Im looking for something to monitor/record speed without having to stick my GPS in my boats, as well as log things like current draw.
    What system are people using? On their site it says their waterspeed pitot tube reads speed accurately up to 50mph...Im looking for something that will record at higher speeds.
    Any suggestions?
    www.keithbradleyboats.com
  • electric
    • May 2008
    • 1744
    Any suggestions?
    There is a gps module that you can get as an add on to the Eagle tree recorder and it works great and is very small. I use that with a LED read out and the temp wires. With that you can get Amps, Volts, Speed, and temps of two different items right after your run and then dump the data to your PC later for more fun.
    • electric
      • May 2008
      • 1744
      You want:
      http://www.offshoreelectrics.com/pro...rod=etr-GPS-v4 (gps speed)
      http://www.offshoreelectrics.com/pro...PRV3-LEADS-150 ( will do a bit more than 150amps, it does volts, total mah used)
      http://www.offshoreelectrics.com/pro...tr-power-panel (will allow you to see whatever you want to see (like max amps, max speed, volts, mah used etc..) This let's you to see how you did right away. Later you can dump it down to you PC.
      http://www.offshoreelectrics.com/pro...=etr-temp-loop (Temp Sensor)
      There are some other sensors as well.... The logger will handle three temp sensers, one rpm, one throttle, LCD screen, usb connection(for your pc), one gps.
      • electric
        • May 2008
        • 1744
        This is really cool and it works great.
        This guy gives you lot's of data real time while you are going. I use it quite a bit so I don't have to guess about the batteries condition while I am running. Only thing it can't do is speed.
        • electric
          • May 2008
          • 1744
          Last, but not least is this:
          http://www.offshoreelectrics.com/pro...?prod=dh-wu100
          Very good for what it is, but no speed. I have used all of these items at one time or another...
          • v-spec
            Banned
            • Jun 2009
            • 940
            I just got my castle ice esc setup it records pretty much everything but speed with no extra wiring.
            • electric
              • May 2008
              • 1744
              [QUOTE=v-spec;215295]I just got my castle ice esc setup it records pretty much everything but speed with no extra wiring.[/QUOTE
              Did you get the 200amp model? I am wondering about whether it is better to get an ICE 200 vs a Castle Hyra 240. Are you adding water cooling to it?
              • v-spec
                Banned
                • Jun 2009
                • 940
                [QUOTE=electric;215483]
                I've got the 100 version. I'm trying to decide right now whether I wanna buy the 200 or not. No water cooling.
                • video200
                  • 837
                  are there not a hydra ice on its way ? think i read somewere that it had been added to repair chost
                  • v-spec
                    Banned
                    • Jun 2009
                    • 940
                    It's been on it's way going on what 2 years now?
                    • video200
                      • 837
                      diddent know the ice been around that long
                      • v-spec
                        Banned
                        • Jun 2009
                        • 940
                        Maybe a year and some change I'd guess. What I mean is they've said they were working on the hydra ice since the normal ice came out.
                        • video200
                          • 837
                          i been whanting a ice 200 for a wile. but i keep beeing put of by the failing hydra`s
                          it shure do have some nice gadgets
                          • keithbradley
                            • 3663
                            Anybody ever try one of these?
                            • v-spec
                              Banned
                              • Jun 2009
                              • 940
                              http://www.eagletreesystems.com/Boat/boat.html
                              I've been looking at that for a while but I just don't want a mess of wires in my boats that's why I got the castle esc. I would like to have the logger but i'd probably end up having somebody else watch it for me so I can drive the boat instead of looking at the screen.
