Whats a good Fe tunnel hull ???
  • Brushless01
    • Apr 2010
    • 487
    So whats a good one ??
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
  • Kris Flynn
    #2 Bench Racer
    • 229
    What Size?
    IMHO The Vision 20 is a great boat for P-Spec (even P) it is 29.25" long
    Other goods ones are the VS1, Cobra
    Kris
    • Deserthobbies
      • 50
      Check out the new proboat stiletto, supposed to be out in about 3 weeks.
      • Doug Smock
        Moderator
        • 5272
        Originally posted by Insaniac
        I would second that on the ProBoat...I have a VS-1 set up as an FE and it's great as long as there are no boat wakes, but it tends to trip and spin out a lot...
        You may need to work on your set up.
        There are three at the club that are rippin and snortin with UL-1 motors, and modded 4255s.
        MODEL BOAT RACER
        IMPBA President
        IMPBA 19887L CD
        NAMBA 1169
        • boogaloo_d
          • Aug 2009
          • 42
          I run a Hydro&Marine F-1 Skater with a UL-1 motor and ESC, and it good boat. It's easy to drive and very stable. Its fast too.
          Doug we had a great time running with you guys in Atlanta. Cant wait to see yall at the SOEGA race.
          Jimmy Duncan
          • Brushless01
            • Apr 2010
            • 487
            Is the graupner tunnel any good ??
            • Doug Smock
              Moderator
              • 5272
              Jimmy Duncan
              It was great to have you guys Jimmy!!
              We could have done without the two flash floods, but other than we had a blast!!
              See ya in Sycamore,
              D.
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • longballlumber
                • 3132
                I am currently running a VS-1, OS leg, modified grim 42X55, UL-1 power (speedo and motor) and it will run with the best of them. Mine runs 42-45 mph all day long. It's super stable and a ton of fun to drive.
                I would also take a look at the TS3 that will be released soon by AquaCraft. I raced the Prototype version at last years nationals with the same set up as above, only I was running a modified M445. It's a little longer than the VS-1 so should handle rougher water (as long as it's properly set up). I will be looking at getting one this fall for a winter build.
                Later,
                Mike
                • Brushless01
                  • Apr 2010
                  • 487
                  Will there be a fe ts3 ???
                  • Doug Smock
                    Moderator
                    • 5272
                    I'll take any and all suggestions as far as drive depth and angle. COG is at 8-inches and the VS-1 flys at an angle of between 2 and 5 degrees...problem comes with wakes where it spins out and "trips" usually flipping over. It came with stumble pads installed.
                    If you'd like send me your email address in a pm.
                    I have Trini's VS 1 in the basement and she's a runner.
                    I'll send you some pics, maybe you'll see something that will help you out.
                    Doug
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • longballlumber
                      • 3132
                      Like most tunnel's you will need to convert for FE use. If I can do it, anyone can!!!
                      Later,
                      Mike
                      • longballlumber
                        • 3132
                        Which lower unit are you using?
                        Later
                        Mike
                          • 9488
                          I think the TS3 looks sweet
                          • eboat
                            • Aug 2007
                            • 693
                            Vision 20 is better
                            I had a TS2 but the vision 20 is way more stable
                            All white boat is the vision 20 the coloured one is the TS2
                            • adamb
                              • May 2010
                              • 110
                              Anyone run the bby tunnel?
                              BBY Scat Cat 26 8xl &sword fish 120
                              Vac-U-Cracker 20turn brushed car motor
                              Dumas Lil Rascal 7L!
