Need some help!!!
  • k10smith
    • May 2010
    • 35
    Need some help!!!
    Iwant to put a new motor in this boat put can't find a Motor Coupler to fit this set up
    the motor that was in there was a 1/8 shaft which is in the pic with the adapter that came with it the motor i got has a 5mm shaft
  • andym
    More Go Than Show Prop Co
    • 2406
    What sizr is the wire in the drive ?? http://www.offshoreelectrics.com/pro...Motor+Couplers Scroll down and you will find 5mm shaft grub screw wire drive couplers
    • k10smith
      • May 2010
      • 35
      it's one soild rod it's got to be 1/8 because the adapter i have now is one size and the motor shaft fits perfectly in which is 1/8 shaft. the boat is a DRAGON V24 MDF 860EP
      • andym
        • 2406
        I do not know the boat , can you bore 5mm into your original coupler ? If not get hold of Jeff Wohlt here on OSE and he will make you one.You can find him in the members list
        • k10smith
          • May 2010
          • 35
          Thank you
          • Basstronics
            • Jun 2008
            • 2345
            I second Jeff. Hes the coupler and wire drive man.
            Just be aware hes on vacation until the 26th.
