Rio 51 conversion
  • Brushless01
    • Apr 2010
    • 487
    Rio 51 conversion
    Im thinking about converting my rio to electric how fast do you think iot will go with this stuff ??
    http://www.offshoreelectrics.com/pro...runner&cat=135
    http://www.hobbyking.com/hobbyking/s...dproduct=10332
    http://www.hobbyking.com/hobbyking/s...Long_Lipo_Pack
    4 of those packs for 12s2p ?? and what prop ??
    Thanks Alex
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
  • Doby
    KANADA RULES!
    • 7280
    Links don't work???????
    Grand River Marine Modellers
    • Brushless01
      • Apr 2010
      • 487
      http://www.hobbyking.com/hobbyking/s..._Brushless_ESC
      • Doby
        KANADA RULES!
        • 7280
        The Rio is a great looking and sounding boat done up for FE. I love mine and its always a crowd pleaser.
        BUT......one thing to keep in mind is that its essentially a 51" Super V as to its handeling characteristics. In a straight line even in some chop its fine but cornering in that same chop is interesting and it can roll over if not careful. Its a horrible cornerer at those speeds whereas a Delta Force type hull will just power through the chop full ...speed ahead with little or no issues.
        Its not the boats fault...it just wasn't designed for those speeds. Also, fully loaded it pushing around 21 pounds so its a bit "porky".....
        The standard drive shaft is not suitable either for the strains of a FE setup, I have broken numerous shafts right where its stepped down to 1/4"..(gets expensive replacing props, shafts, drive dogs etc.... Get a good aftermarket flex shaft assy.
        The hull is actually built like a brick shi...house. Its taken quite a beating over the past few years, flipped, rolled, hit markers, been hit by other boats etc and has held together well. (filling the bow with expandable foam has really helped it hold together in my opinion).
        • Brushless01
          • Apr 2010
          • 487
          Would the stuff in the links work ??
          • Brushless01
            • Apr 2010
            • 487
            • Brushless01
              • Apr 2010
              • 487
              There must be somebody that knows !!!!
