Mhz Mystic S turning problem
  • bjornar
    • Nov 2008
    • 83
    Hi
    My twin Mystic S turns when I drive straight. It takes pretty sharp turns just out of nowhere. I havent had it in any high speeds yet, because of this problem... Original setup is: 2 x Neu 1515, 2 x Turnigy 180A esc, 2 x Rhino 4900 4S Packs. I have tried to switch to Feigao 540XL and CC Hydra 120A without any difference. Can the boat be to heavy? Please help me :-)
  • nomobux
    • 165
    Better servo ?? stronger linkage ??
    • bjornar
      • Nov 2008
      • 83
      The servo should be good enough, its a Futaba S9551. I also tried to switch to a Power HD servo just to try. The linkage it SS push pull system, cant see thats the problem.
      • Diegoboy
        • Mar 2007
        • 7244
        What is your radio? Have you done a range test?
        does it happen at a certain distance?
        • bjornar
          • Nov 2008
          • 83
          Its Futaba 4PK. I cant drive at all, it happens all the time and both ways.
          • Diegoboy
            • Mar 2007
            • 7244
            Hmm... What props are you running?
            • bjornar
              • Nov 2008
              • 83
              I am running plastic 40mm from OSE (L & R)
              • Diegoboy
                • Mar 2007
                • 7244
                Graupner K series? 1.4 pitch...
                Do you have any video of it doing what you describe?
                • bjornar
                  • Nov 2008
                  • 83
                  Yes, Graupner K 1,4 pitch.
                  I will try to get a video later to day.
                  Thanks for feedback.
                  • steveo
                    • 1454
                    are your props spinning inward or outward? how deep is your rudder
                    • bjornar
                      • Nov 2008
                      • 83
                      See picture.
                      • Diegoboy
                        • Mar 2007
                        • 7244
                        You're running inward. (more stability)
                        try reversing the rotattion to outward (more speed) AFTER you figure out the issue first!
                        • ED66677
                          • 1300
                          you said you switched from NEU's to Feigao's and still she turns in straight right?
                          so this doesn't seem to be a motor/power difference between L and R!
                          does she turn slowly or is it brutal?
                          are you running L and R flex? that might sounds to be a dumb question but... if not then one flex unwinds and creates more friction so less power at prop is the result.
                          beside of this, I can't see any water pick up, are they flush to the bottom?
                          Emmanuel
                          • steveo
                            • 1454
                            is there any play in your rudder left to right
                            • bjornar
                              • Nov 2008
                              • 83
                              No play in the rudder.
