Hi all,
I'm a relatively new boater. I have a SV27 I just overhauled/upgraded from stock. 5S-5000-150a pack, Feigao 540 7XL motor, 180 amp Hydra ESC, Graupner CF42 prop (prop is a bit big for this setup but I only do short runs).
So I just got it in the water for the first time today. At first I was using 14 cells NiMH for a test run. Everything went well. Motor and ESC running cool.
Then I pop in the 5S. This thing was HAULING. My lake, at the short end, is roughly 300 feet across. It was traversing that in about 3.5-4 seconds if that. WAY too fast for my relatively small lake. But it was going like a shot. Everything is running smooth for about 4 minutes, then it happens. My boat stops, when I give it throttle it's whirring but no forward motion. I'd figured I might have lost my prop. It seems to be sinking fast. So I get out the recovery boat, wind it up and bring it in.
Turns out my drive cable was literally sheared off where the drive cable enters the drive tube. Took the prop and most of the drive cable out the rear when it sheared, which is why it was filling up so fast. The motor shaft was bent (managed to get it 99.9% back to where it was). I've been trying to figure out the reason for it.
A few things. First, my drive coupler didn't seem to fit my motor shaft quite well, although they're both 5mm. It was just the slightest bit sloppy. Second, there was no inner liner protruding out of the front end of the drive tube. I'm thinking maybe the drive cable was chaffing up against the brass and, because of heat, friction and sharpness, finally cut it in half?
Anyone have any other ideas? I love the setup! The motor will need a bit more cooling for sustained running (the ESC still runs cool) but the the thing just flies! I'm figuring round about 55 mph or so and stable running pretty dry on near mirror water. Would like to GPS it when I get it going again.
So I don't know about the drive cable shear. It was a bit old so maybe that figured in . Any ideas/advice/suggestion much appreciated.
Rob
Rob
