P mono 55+mph set up
You may also want to check out the MHZ Lizard Extreme and the DF cyberstorm. I have no experience with these though.If all of your wishes are granted, many of your dreams will be destroyed!Comment
I love my Seaducer SD3 , carbon electric lay up 1515 1Y and a M447 back cut, bar cut and pitched up. Regulary 55-59 mph racing gassers and that = rough water. I think any of the hulls mentioned will do the job it is all about SET UP end of story !! HP does not mean faster if your set up is off. You need to know how to set it ie; strut depth, correct prop, strut angle and CG for different conditions. No point having a loose set up that will do 60 in wind and boat generated chop. Better off with a boat locked down some and doing low 50's. Same boat calm day and a little chop loosen her up and hang on. So I think a lot of guys chase power at the expense of LEARNING set up.Comment
The DF cyberstorm looks sweet I might have to pick that one up. I am going to just try to make my Arowana competitive for this season. I might go with the lepord motor ose has or just run a one of these http://www.himodel.com/electric/2075...0_3674-8T.html
and a x440 3 blade prop. this is a guy on Rcgroups with the 8t motor and 3 blade x440 set up
I agree that setup is key to any boat. All hulls have limits too. They all have strengths and weakness. No matter what you choose. Test, test, test and have fun doing it.If all of your wishes are granted, many of your dreams will be destroyed!Comment
well i got a leopard 1515 so we will see what happens I am going to run the hull I have for now get my driving down then look at a new hull over the winter or next spring. Still sourcing batts but should have some soon. any recommendations for a prop other than a m445?Comment
Jason, I'm pretty sure Dick lets you guys run what you want in the OD club races but if your planning to run at the district race we have a rule that the P-mono's cant be significantly faster than the nitro guys. It's a consession we made to have the district let us run together.
That being said, I run one of Chucks X642's with a 1515 1Y in my Titan 33 and I'm as fast if not a couple mph faster than any B-mono out there. I also run a pound of lead in my boat. Like others mentioned above, once you get her together, do your time at the pond and set that sucker up to run in sloppy water. You definately have a better chance making it to the podium with a boat that finishes all it's heats rather than one thats faster and ends up on it's lid half the time.Mike Chirillo
www.capitolrcmodelboats.com
Jay, I built a 33.5" Wildthing around the same setup. Where's a good place to start testing prop wise? M447 until I get it sorted?
