Help- Flex shaft seizing in strut
  • ALD
    • May 2010
    • 96
    I installed a new .150 flex w/new strut. I used a 3/16 gap between strut and prop. I used teflon with the shaft and cut it longer so that it would fit into strut further. Could this have caused the shaft to sieze in strut?
  • 785boats
    Wet Track Racing
    • Nov 2008
    • 3169
    If you don't pull the shaft & grease it after every session & it is running dry , the friction & heat buildup can melt the teflon & cause it to bind up on the flex.
    Is this what happened? Or is it the stub shaft in the strut bearings that siezed?
    Paul.
    • ALD
      • May 2010
      • 96
      The stub shaft in the strut bearings siezed.
      • properchopper
        • 6968
        Is your prop well balanced ?
        • ALD
          • May 2010
          • 96
          Prop- new/balanced and shapened. Lube everything just before running. The only thing I did was change the length of the teflon tube. Made it longer to fit into strut better. I think when I did this it did not allow the shaft to shrink. I kept a gap of 3/16. What do you guys think. Would this cause it the stub shaft to sieze in the strut?
          • egneg
            • 4670
            Did everything turn free by hand before you ran the boat?
            IMPBA 20481S D-12
            • ALD
              • May 2010
              • 96
              Yes, everything was spinning free. After 2min on the water at nearly full throttle boat came to a stop.
