a few questions before i begin
  • ozboater
    • May 2007
    • 415
    is it worth really upgrading to a wire drive ?? doesn t seem to be much more $$$... plus steve is out of the octura flex right now :) any suggestions as to what size would do the trick ???
    cheers
    oz
    • forescott
      Hopelessly Addicted to RC
      • 2686
      I would, no teflon tubing, no worries about drive dog/prop shaft gap, less chance of water being drawn up the stuffing tube via flex shaft. Jeff Wohlt is a member here and has a website with all the parts to hook you up. http://rcraceboat.com/StorePAGE.html
      • ozboater
        • May 2007
        • 415
        seems like there are more benifits to wire drives if you use a forward motor mount, ie a long stuffing tube.... i was planning on placing the motor toward the rear of the boat so i might just stick with a flex... the 9xl is a pretty heavy little motor... reckon i ll be able to get the correct COG if i mount the motor just froward of the transom ?? is a wire drive worth the extra $$$ if it s only gonna be 4" s or so ??
        cheers
        • ozboater
          • May 2007
          • 415
          anyone got any first hand experience with trim tabs on the df29 ??
          cheers
