CC hydra 240 settings for Neu 1521/1.5D
  • LuckyDuc
    Team Ducati Racing
    • Dec 2008
    • 989
    Just curious as to the settings I should use on my CC hydra 240 with my Neu 1521/1.5D. Will be using 4S lipos.
    TIA.
  • Rumdog
    • 6453
    timing at 0 for D winds. All they do is heat up with any timing advance.
    • LuckyDuc
      Team Ducati Racing
      • Dec 2008
      • 989
      Cool. Thanks.
      Do any of you mess with the throttle and brake curves, or should I just leave them alone?
      I assume a start power set to "normal" is fine as well.
      • BakedMopar
        No Mo Slipah
        • Sep 2009
        • 1679
        I have been running mine at 0 degrees also. Yesterday was the first time I changed it to 3 degrees. It was only a tad faster and temps were same. It did however seem to run a little smoother.
        • D. Newland
          • Dec 2007
          • 1030
          I run my P mono with this setup and have always used the "low" timing setting default by Castle (7 degrees?). I've never had any heat issues, be it running as P Offshore or with a hotter prop for P mono. But, I don't think I'm maxing out the motors potential, either.
          Best thing to do is test and monitor temps. Every setup is different.
          • RaceMechaniX
            • Sep 2007
            • 2821
            I run mine with 3 degrees of timing and very healthy props. Extra cap bank helps a lot too.
            I did change the throttle settings to a more progressive curve and disabled the brake.
            Tyler
            Tyler Garrard
            NAMBA 639/IMPBA 20525
            T-Hydro @ 142.94mph former WR
              • 8012
              I use four degrees advance with that motor, I wouldn't use "low" as it can go too high. I also use stock throttle curves, but 12% reverse. It is interesting how often I use the reverse when I have it available .....
              • Jeepers
                • May 2007
                • 1973
                I have my esc set to 4 degrees.I have not seen any temp increase over the 0 degrees timing, but like D newland I am not maxing the motor either, I am just turning a m648 on my Whip 20.
