Scuffing hull another proposing ?
  • SweetZ28
    • 1322
    well after seeing all the fuss about wether scuffing the boats bottom will make you go faster some guy's swear on it but yet i do not get this if it works then why do guy's?
    polish there props wondn't if you wet sand them fully dull a layer of water will stick to the props surfaces( like on the hulls bottom when scuffed) thus making the prop spin faster because it will cut through the water easy because water on water is slipereir than a shiny surface is? if it works on the hull it should do the same on the prop...so why does everyone polish the props.... why not polish your hulls bottoms then?
    WWW.PPRSLOTS.COM
  • Rumdog
    • 6453
    This has been discussed quite a bit actually. "Everyone" don't polish them. I never have. The only way to test the theory is to run the exact ame rig on the exact same prop, one polished, one non. I can't see how it would matter either when it is tearing through the water at 30,000 rpm. I think it's just more of a preferance in look. Sharp and balanced is the key.
    • Flying Scotsman
      Fast Electric Adict!
      • Jun 2007
      • 5190
      I am just lazy and wet sand them with 600 grit. I do like the look of a buffed prop though and it is virtually impossible to prove whether one method is better than the other.
      Douggie
      • Rumdog
        • 6453
        Yeah, me likes shiny things too.
        • Jeepers
          • May 2007
          • 1973
          Jay Turner has said a few times that a satin finished prop is faster than a polished prop? maybe he will chime in and give a good explanation. me I just finish with 400 when I feel like it, mostly because my props take a beating there is always some piece of wood, or turtle that I end up hitting
          • Jeff Wohlt
            • Jan 2008
            • 2716
            Tom at Octura will tell you the same...leave the matte finish on it. S&B and run it.
            www.rcraceboat.com
            jwohlt5362@yahoo.com
            • SweetZ28
              • 1322
              I say if matt finish works on boat hulls it should be the same on a prop same thing is happening you want it sto slip and cut through the water as easy as possible..... I say matt finish is the way to go!
              WWW.PPRSLOTS.COM
              • m4a1usr
                Fast Electric Addict
                • 2038
                Say what you want but we can all take a lesson from REAL boats. Not the RC kind. All of the high performance boats from monos, hydros and Cats that are in the winners circle run polished props. At least those who run wide open and not in a closed circuit race. There is a slight performance increase in a polished prop over one that is not smooth finished. Need proof? Try reading about prop performance from the makers of real props. There's a herd of them out there. Go to the pits of the unlimited hydros. You wont find one prop that does not shine like a mirror
                And then theres sources like, http://www.rcprops.com/TechNotes/rcprop_tech_info.htm
                John
                Change is the one Constant
                • Karfrik
                  • Jun 2009
                  • 1177
                  Less friction= more speed.But i do also question this for the hulls.Back in the day i used to polish my real boat hulls including sailboats.Now i scuffed my rcboat hulls....................lol....i just go with the flow!!!.......,Albert
                  • SweetZ28
                    • 1322
                    maybe with a prop they make it shiny so it grabs the water harder so it launches the boat more efficently?
                    WWW.PPRSLOTS.COM
                    • Rumdog
                      • 6453
                      John
                      Water doesnt scale. It isn't the same on a r/c boat prop vs a prop 1 ft. plus in diameter.
                      • MarkF
                        dinogylipos.com
                        • Mar 2008
                        • 979
                        Polished props have a little more bite out of the hole. Which is good when you spin out in a race and need to get the hull on step quicker. Iv'e always polished my saw props because some of the props we use cavitate alot. Iv'e tryed my props with the satin finish before I polish them but I didn't notice any difference in speed.
                        Mark
                        • m4a1usr
                          • 2038
                          Quite the contrary. Fluid friction does not have scale issues in calculations. Its a constant for an item whether its 1" in dia or 10 feet in diameter. Fluid dynamics are calculated in the amount of force due to viscosity, surface finish or texture and shape of the object. If you take scaled props of exact design and proportion but of different sizes the friction coefficient will be exactly the same. Thats why its a constant providing they are operating in the same media.
                          John
