motor suggstion for Titan 29
  • Joe Friars
    • Dec 2007
    • 99
    Hey all; I have been colecting parts for an aeromarine titan 29 build.
    I've come across people using 8xl-10xl. and running 4s-6s. I understand that by runnng 6s, I would have a lower amp draw,but.....
    I would appreciate our opoinions/recomendations. I am looking for most reliable setup and best speed without overpowering the hull.
    Thanks
    Joe
    Joe Friars
  • Diesel6401
    Memento Vivere
    • 4204
    What kinda money you want to spend, Feigao $$$ or Neu $$$.
    - Diesel's Youtube
    - Diesel's Fleet
    • Flying Scotsman
      Fast Electric Adict!
      • Jun 2007
      • 5190
      The prop is the real answer to your question and what is most important to you...speed....reliability...run time?
      Douggie
      • Joe Friars
        • Dec 2007
        • 99
        I am looking at Fiego $$$.
        As for prop size I am thinking x440-442/640-642.
        As for what I want I would have to say, Speed, but not crazy too much for the hull no fun speed. then reliability and run time.
        thanks
        Joe
        Joe Friars
        • Flying Scotsman
          • Jun 2007
          • 5190
          X640... 9 XL.. 4S
          Douggie
          • Joe Friars
            • Dec 2007
            • 99
            Simple and to the point.
            Cheers
            Joe
            Joe Friars
            • properchopper
              • 6968
              Titan 29 ; 9XL/4S2P Neu 4100's, X442 ; get's a little hairy over 50 mph.
              Moving motor rearward & putting batts on keel line improved handling, BTW
              I now run a BJ 1500 KV motor with Turnigy 4S2P 3600's , UL-1 SC , hub cut X442 for LSO [ 4.5 min] with a cooling fan & really like it for a low-buck fun runner. Mid/High 30's. More prop, likely @ 40 mph.
              • Joe Friars
                • Dec 2007
                • 99
                Cool vid. Thanks for the motor mounting tip. I was thinking of going in that direction. Do you have a picture of your setup inside the hull?
                Cheers
                Joe
                Joe Friars
                • Chilli
                  • Jan 2008
                  • 3070
                  10 XL, 4s2P, M545, Etti 150. Low 40's. Cool, fun & reliable. Plenty fast for that hull.
                  I have this set up in my two sons Titan 29 and Mean Machine.
                  Mike Chirillo
                  www.capitolrcmodelboats.com
                  • properchopper
                    • 6968
                    I started out with a 10XL ; less heat, more runtime = more fun.
                    • properchopper
                      • 6968
                      Cheers
                      Joe
                      Here 'ya go [ with the 9XL or 10XL move batt's forward @ 1.5" {this is my LSO setup}
                      • Flying Scotsman
                        • Jun 2007
                        • 5190
                        Interesting answers..I do not own a Titan 29 but I do own a DF 29 and my speed setup is as I stated for that hull and I do agree that for less heat etc. a 10XL or similar motor is a better choice.
                        Douggie
                          • 9488
                          What's a good CG on this hull?
                          • properchopper
                            • 6968
                            Todd, there's no easy answer to this. Factors to consider : distance of transom - to - prop { I use a shortened Speedmaster stinger}, prop lift, type of water, e.g sticky glass, small chop, racewater; aerodynamic hull lift ( the T29 gets airborne much over 50 mph) and so on. Confused already ? Test & tune each boat will reveal the answer !
                              • 9488
                              Ok, after seeing the picture of your T29, I got worried because my batteries are about 3-4" forward of yours..
