pursuit mono
  • boatman cmbc
    • Feb 2010
    • 159
    pursuit mono
    2075kv xl motor, turnagy 180 esc zippy 4900 30c lipos. starts good but then goes to half throttle. 4s1p is what i am running will 4s2p double my c rating? i think whats happen is the lvc is kickin in . help
  • Jeepers
    • May 2007
    • 1973
    what voltage, what prop?
    • boatman cmbc
      • Feb 2010
      • 159
      pursuit
      14.8, 642 octura
      • JMSCARD
        • Mar 2010
        • 3444
        Turn off the LVC on the esc... If its the older turnigy 180 before the version 2 it was a known problem... The Auto calculator for the cell count never works... I have 5 turnigy 180's the older versions do this.....
        • boatman cmbc
          • Feb 2010
          • 159
          pursuit mono
          jmscard, i will try that. i'll let ya know how it works out.
          • vasy
            • Dec 2009
            • 333
            Running with out LVC can be bad for lipos if you get overly exited not?
            What about pre-setting for the number of cells so you are not using auto-calc?
            I noticed that stock 120 LVC seems to kick in way early unless you set it to 3.2v.
            • boatman cmbc
              • Feb 2010
              • 159
              pursuit mono
              vasy u are right but i only run 5 lap races and it sits on the shelf. so far after 5 laps i have not reached even close to danger levels so i feel good about the lvc being off. by the way, it really hauls.
              • vasy
                • Dec 2009
                • 333
                I run it on 2200kv 4500mah 40c 14.8v and x642 with the stock 120amp and get about 2 minutes solid run-time before LVC kicks in, but that is WOT all the time, even in turns.
                I'm not sure why you need 180 with a lower KV motor. I'd say it is fast, but not that fast.
                On 5 s it start to pick up speed :) but that ESC shuts down to 1/2 after 1 lap.
