Motor amp draw?
  • Basstronics
    • Jun 2008
    • 2345
    Motor amp draw?
    Hi Guys,
    looking at an eagle tree.
    Here is the largest motor I have:
    Max Amperage of 78 Amps... Is it possible I might go over the 100 amps the lower Eagle Tree records?
    I dont think I will have a larger motor that this ever, but suppose it may be possible.
    I would love to save $30 if possible. If not, well I wont die over it I guess...
  • Rumdog
    • 6453
    Hull? Prop? It can pull over 100 amps if the setup is improper.
    • electric
      • May 2008
      • 1744
      Take it from a guy who demagntized a motor. Yes you can. Quite easily actually. Just put a slightly too big prop on or have the hull run too wet. Not a good practice to say the least, but I would spend the extra 30 bucks. Then at least you will know you have some room and who knows what your next boat or motor will be.
      • Basstronics
        • Jun 2008
        • 2345
        DF copy 25"
        Prop will be experimenting with.
