What is scuffing and how do i do it?
  • scubasteve95
    • Apr 2010
    • 239
    #31
    RD,
    you always have a neg comment...
    how do you know i got rid of the edges from one small pic?
    infact the edges were not touched...you just had
    to puff up your chest and say something negitive..its ok..thats just who you are.
    you dont like the boat...never have and never will...we get it....
    and (old dog)i was talking about the ekos not a bandit or any other boat....you think
    your the only one who knows how to take 800 grit and scuff off the finish.
    like you said it takes 5min.....if you dont have a ekos then you dont have any data.
    • old guy
      • Nov 2008
      • 687
      #32
      Originally posted by old guy
      Data! Bandits gas mono went 4 mph faster when scuffed on the gun we ran it then scuffed it and ran it again all in about 5 min so there would be little change. if done right it works
      You ask for help on here and some poeple give you help and then you slam them for helping It works on all boats not just Bandits boats that was just a example. now if you want to be rude and slam poeple here it is. only a complete ###$$%%%# would do what you did to your boat. Where did I say I was the only one. It's as# ho## like you that stop poeple from helping becouse they do not want the bull Sh##. FLUID said it right and knows how it works some time poeple should listen and keep quiet. so have a nice day
      Sorry to any one I my have offended
      • Rumdog
        • 6453
        #33
        LOL Do you want advice? Or do you just want to try to disprove everyone? Sorry, I'll get off my common sense pedestal. My chest is starting to hurt anyhow. This was not a EKOS thread.
        • SweetZ28
          • 1322
          #34
          Here is how i know that dulling (scuffing )the bottom works. years back i made airboats that where flat on the bottoms that where covered with epoxy and where like shiny glass and i noticed everytime i went over the big lily pads my boat would almost adhear to them and get stuck.... so what i did try is the (scuffing ) dulling of the bottom of my airboats and what it did was make em slide right over the lily pads that would stick to my boats bottom like a suction cup almost stopping them..... so because when you dull the bottom of a boat and then poor water over it it looks like a full sheet of water stays on the bottom and because it worked like this on the airboats the thin layer of water on the boat and on the lily pads acted much more slippery agains each other making the air boat fly across the lillys...so on the water it should do the same.
          WWW.PPRSLOTS.COM
          • scubasteve95
            • Apr 2010
            • 239
            #35
            here we go again....got the old mans panties in a bunch....
            like i said
            ran boat stock got max speed...
            i told you i scuffed the bottom...no change
            i told you i sprayed the bottom...no change...
            tell your fish story to bassmasters.com...
            if your tring to impress somebody this is the wrong forum...
            anybody try this with a ekos or similar boat....
            hay old man you kiss your boy friend with that mouth?
            • scubasteve95
              • Apr 2010
              • 239
              #36
              i was having a chat with someone who had
              a ekos till you 2 gave your 1.2 cents...
              and disprove or not ,unlike you i gave the exact results...
              not an imo or observation...like it or not.
              • NativePaul
                Greased Weasel
                • 2760
                #37
                Picture STA74969.JPG in post #21 clearly shows rounded edges to the ride plates as demonstrated by linear highlights reflected in the bedliner from the lightsource along both the top an bottom edge, you can also see the curve in the glass where the pad meets the step, I am not insinuating that your application of the bedliner made them any worse than they were out of the box, but they are not flat. As it seems you have a way of measuring speed to .1mph, would you be good enough to blueprint the ride pads and see how much difference that makes? I dont have the means to measure speed with anything like that accuracy and I either make my own pads which are dead flat or do my blueprinting before it hits the water, I know it must be good for a boat but have no idea how good.
                • Flying Scotsman
                  Fast Electric Adict!
                  • Jun 2007
                  • 5190
                  #38
                  The point is sanding DOES INCREASE THE SPEED IF DONE PROPERLY.
                  end of story.
                  Douggie
                  • tharmer
                    • 342
                    #39
                    Will somebody please shoot this thread! The kids are at it again.
                    -t
                    • Jeff Wohlt
                      • Jan 2008
                      • 2716
                      #40
                      LOL....it is still a good thread. Sanding and blueprinting is the key. Sharp edges...flat ride surfaces and sharp trailing edges are critical.
                      www.rcraceboat.com
                      [email protected]
                      • T.S.Davis
                        • 6220
                        #41
                        I've been sanding my ride surfaces since the first time Jay explained it years ago. Back when we ran NiCd we needed every last drip of power. On a mono hull you would notice the amperage difference through the course of a race. Lot's of wetted surface in the turns.
                        As for speed changes. Not likely. That's just my opinion though. Think about it. There's not much boat in the water at full boogy. If you have a lot of wetted surface maybe you would see a difference.
                        I haven't messed with testing it. It's just something I do without a thought.....just cuz I always do.
                        Jeff's right on. Straight surfaces and trailing edges you can cut meat with.
                        Noisy person
                        • old guy
                          • Nov 2008
                          • 687
                          #42
                          Yes it is and some how Rumdog and I are the bad guys for saying that Rumdog would you just give scubasteve95 his soother bake so we do not have to listen to him whine any more It's nice to be old and scubasteve95
                          not sure how you think I was trying to impress any one. As for your remarks about my boy friend would you be so kind to say hi to your mom for me
                          See I too can be a #ss and that it all for me on this one
                          • scubasteve95
                            • Apr 2010
                            • 239
                            #43
                            old dog aleast we all know how old you are
                            your age is the same as your IQ around 60
                            and lets all just think for one min.if scuffing was soooo great
                            how come all the rc boat manufacturers RTR or OTHER are not doing it
                            straight out of the box????
                            even traxxas with all of there R&D did not do this to there band new boat.
                            you and rumdog a sippen out the same jug.
                            • scubasteve95
                              • Apr 2010
                              • 239
                              #44
                              ok update....
                              just got off the phone with traxxas.....and.....
                              thay said thay tried scuffed unscuffed and afew other
                              thing all with minamal to no affect...i.e.(its a old wifes tale...end quote)
                              • T.S.Davis
                                • 6220
                                #45
                                Come on Steve. Ya can't quote traxxis as the foremost authority on boats. They've only just started in boats.
                                I don't get along with some of these guys either. Mostly because expereinced opinions get crapped on.
                                Just consider all the opinions and then form your own. Do you have any faith in those providing you their thoughts? Some yes. Some not so much. Heck one of them was a naval engineer that has written books on RC boats. If traxxas knows more than us fools go with their guidance. Some of us can live with that.
                                For me, I'm going with what ever the fastest guys I know are doing. I knew a guy that swore by Rainex. Worked for him.
                                Noisy person
