Motor and ESC question
  • jac4412
    FE Addict
    • Jun 2010
    • 425
    Sorry if this comes off as a dumb question... If I run a brushless motor that says a max current with 45a with a 60a esc does that mean that the esc will burn out the motor? Again, I'm just trying to understand the basics of my boat... Can I get away with a 60a esc or should I use a 45 or 30a esc to run the boat?
    JAC4412 RC
  • Simon.O.
    • Oct 2007
    • 1521
    A motor can and will draw a lot more power than what it is ¨rated¨for.
    The amp rating on a motor is what it is happy with, but be assured that you can pull a lot more.
    The esc does not push power but merely let it through from the pack to the motor.
    If the motor is demanding more than the esc is rated for then the esc will get hot, it may thermal or it may fry.
    The pack has a C rating and if the motor demands more than what the pack is happy to send then the pack gets hot and may show its unhappiness by puffing.
    This may not be the most technical answer but I hope it is of some use to you.
    If you think your motor may pull up around 45A then the 60A esc will be fine.
    • Make-a-Wake
      FE Rules!
      • 5557
      "If I run a brushless motor that says a max current with 45a with a 60a esc does that mean that the esc will burn out the motor?"
      No. It means the ESC has the capacity to provide amperage the motor needs. However, if you overprop the motor, you could easily be over the 60a continuous rating and burn it out. Do not use a smaller ESC, it will fry for sure.
      • jac4412
        FE Addict
        • Jun 2010
        • 425
        So the 60a esc should work fine with that motor? And when you mean overprop the motor, thats basically setting it up so that the motor will demand more power and burn out? And using a smaller esc would be if I used a 30a esc? Thanks
        JAC4412 RC
        • Simon.O.
          • Oct 2007
          • 1521
          One more thing I forgot to mention is that if the motor is not appropriate for your hull size and prop, all bets are off too.
          I could throw a 450 heli outrunner in my big rigger and all kinds of smoke would quickly appear.
          The 6XL from the big rigger would sink the min cat !
          What have you got so far?
          Hull?
          Motor ?
          Battery pack(s) ?
          ESC ?
          Props ?
          • jac4412
            FE Addict
            • Jun 2010
            • 425
            Motor is a 3700 motor with several ESC, 30a, 60a, and 80a, just a standard proboat prop from the 26 shockwave (not brushless) so ill need a new prop, suggestions would be welcome. The hull is just a plain d vee hull, not sure what it is, I picked up a bunch of parts and such at a yardsale relatively cheap... the parts are mostly brand new still in wrap. Battery backs I have several from nimh 7.2v with different amp ratings all the way up to 11.1v lipo (which I was planing on running with the escs and motor, all of the esc are for brushless motors)
            JAC4412 RC
            • jac4412
              FE Addict
              • Jun 2010
              • 425
              the hull size is 24 inch I believe
              JAC4412 RC
              • Make-a-Wake
                FE Rules!
                • 5557
                What is a 3700 motor? Is that the KV......brand code................etc. What is the size.......36-56....28-48 etc..................and the kv.
                • jac4412
                  FE Addict
                  • Jun 2010
                  • 425
                  the rpm/v is 3600 bl is 2845.. no idea what the brand is the motor is just in a bag. Max current is 45a
                  Thanks for the help everyone, its much appreciated, sorry if I'm not really knowledgeable yet, I'm trying to get my bearings in this
                  JAC4412 RC
                  • Make-a-Wake
                    FE Rules!
                    • 5557
                    Ahhhh..........the ol' "bag motor". 3600kv is too high for 3s in my opinion........2s or 7 cell nimh seems like a good place to start. Seems like it may be ok for a 24" hull.
                    • jac4412
                      FE Addict
                      • Jun 2010
                      • 425
                      Ok, then I'll try it with some 2s... Any recommendations for a better motor for a 24inch hull? And yeah unfortunatly it was the only thing not really still with the packaging so for now I'm just hoping itll work out ok to tinker with.. we'll see.
                      JAC4412 RC
                      • Make-a-Wake
                        FE Rules!
                        • 5557
                        You could throw this in it for just a little $$............on 3s that boat would scoot.
                        http://www.hobbyking.com/hobbyking/s...300kv_Inrunner
                        • jac4412
                          FE Addict
                          • Jun 2010
                          • 425
                          thanks.. any suggestions on a prop?
                          JAC4412 RC
