DF 33 Prop Size
  • nova68
    • Jul 2008
    • 151
    DF 33 Prop Size
    I have Delta Force 33 with a Neu 1515/1Y running on 4S2P and running a Octura X 442. I see some guys are running the M 445 what does the M 445 do for that boat and are sun of you running a different prop and what does it do for you. Is the M 445 a lifting prop like for a Hydro ?
  • video200
    • 837
    not shure what the m445 do for the boat. but my df 33 cyber loves the X642 and x645 (on nemesis blue 13xl on 6s)
    there are a vid of it in the video section running a 645
    • mappo
      • Feb 2010
      • 488
      Do you know what the biggest problem with the world is?
      That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
      • m4a1usr
        Fast Electric Addict
        • 2038
        The X-series Octura props are low lifting props and the M-series are basicly the X-series but with the tongue removed.
        The 1515 is a great motor in the DF33. Not the fastest motor you can put in it but its hard to argue with the performance one can achieve with the 1515 can. Here is a link on another members build. Good info!
        John
        Change is the one Constant
        • nova68
          • Jul 2008
          • 151
          DF33 Prop
          Thanks for some of your input on some of the props I feel that M445 and M447 would be a good choice to try.
          • Doug Smock
            Moderator
            • 5272
            What ESC??
            Be very careful with a M447. I like a M445 back cut approx 1mm running a Hydra 240.
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • tth
              • Apr 2008
              • 1510
              I used to run a 1521/1y in my DF33. The motor was never hot. Always around 115-120*F. With this particular motor (1521) you could run 4s or 6s. Either way was a blast. On 6s the boat loved the M445. Speeds were in the mid-high 60's. Your setup (1515) should be good with props in the X640,X642,X442,and M445. Just remember each time you change props your boat accelleration and handling will change.
              I also second Doug's comment the 447 may be a little much.
              • nova68
                • Jul 2008
                • 151
                DF 33 Prop
                Doug i am running a Hydra 240
                • Doug Smock
                  Moderator
                  • 5272
                  Try the BC M445.
                  Doug
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
