Safety with beryllium copper
  • BHChieftain
    Fast Electric Addict
    • 1969
    Hi,
    I know we talk about being careful when sharpening/balancing beryllium copper props. I looked up the following from OSHA on working with this material:
    http://www.osha.gov/dts/hib/hib_data/hib19990902.html
    What are the common safety practices folks use when sharpening/balancing props? IE, what type of respirators do you use, etc?
    Chief
  • tth
    • Apr 2008
    • 1510
    The person working with said material should be using particulate filtration. Preferably with a N95 or N99 designation.
    These are what I use.
    Here and Here
    • Basstronics
      • Jun 2008
      • 2345
      I live a few miles from one of the largest Beryllium plants in the world. I know people with the berylliosis disease. Its not pretty.
      In the said plant, in certain areas that dont meet OSHA regulations for safe particle amounts you must wear a respirator.
      Also note in said plant when you come to work you wear there clothes, yes all of it. When you are done working you take a mandatory shower and give them back their clothes and wear yours back home.
      Since the Beryllium is in a alloy form with copper- its probably not overly dangerous. but CAUTION SHOULD STILL BE TAKEN.
      The disease is pretty ugly.
      • mschaffer66
        • Jan 2010
        • 335
        I just started doing the balancing/sharpening thing. But my first prop I did the filing under running water...probably not as safe as a mask, but worked fine for me I suppose.
