Does this look right?? pix....
  • 99z286spd
    • Jan 2010
    • 266
    Just wondering....motor works fine. It ended up underwater for 4 hours so immediately after i got it back i took it apart to dry it out ....blahh ...blahh...blahh....but this is what I found. Let me know.
    Its kind of a wierd material that can be scrapped off the rotor..
    Aeromarine Challenger,Warehouse hobbies Man O War, Traxxas Blast Rescue Rig, AQ UL-1 Yellow, BE REVO,T-Maxx, Vorza, Baja5B, and the latest addition Baja5T, Wife's gunna keel mee!
  • HappyOne
    • Jul 2008
    • 179
    Sorry, I have never had one apart to know.
    Grand River Marine Modellers, el Presidente
    IROC VUP, 25" Prince Mono, Mini Hydro, Classic Barrel Back, brushless Mini Rio and two Nitro Tunnels
    • 99z286spd
      • Jan 2010
      • 266
      ummm ok.....
      Any one out there who has??
      • Shooter
        Team Mojo
        • Jun 2009
        • 2558
        Ahhh... I believe that's a magnet on the rotor there. (windings around the can.....hence "brushless").
        If it works and you are getting the same speeds, it's probably fine....but beware....I've seen speed controls fry from bad motors. Hopefully someone a little more knowledgable will chime in.
        • m4a1usr
          Fast Electric Addict
          • 2038
          Isnt that the kevlar wrapping you see on the rotor?
          John
          Change is the one Constant
          • 99z286spd
            • Jan 2010
            • 266
            Im not sure what its supposed to look like new It is a Fiagao 580 8L. Do they come wrapped in kevlar?
            • ray schrauwen
              • 9472
              They do come wrapped as per an old thread. Steve V. said the newer ones were wrapped.
              Dunno what happenned to yours??
              Nortavlag Bulc
              • BakedMopar
                No Mo Slipah
                • Sep 2009
                • 1679
                Is the carbon comming off? I had one of these do it. It still worked but mines was a lot worse. Check out my Rico build thread as someone else had the same thing happen. Too bad that these little things happen as this motor is a real workhorse.
                • CornelP
                  • May 2009
                  • 745
                  I just had one open last week. Yes, that is carbon, as installed on all 580s in the last couple of months. They had issues with rotors shattering... so do not scrape it...
                  • RaceMechaniX
                    • Sep 2007
                    • 2821
                    Yup, Its carbon tow(single strand string). They use the carbon to strengthen the structure without impeading the magnetic flux. Helps hold the magnet(s) in one piece from the centrifugal stress at speed. Neu's also have the same construction.
                    On a side note: Super high speed motors use an Inconel and even higher strength sleeve materials to keep them together albiet they sacrifice some efficiency.
                    Tyler Garrard
                    NAMBA 639/IMPBA 20525
                    T-Hydro @ 142.94mph former WR
