SV motor on a gear drive.....
What about running the SV motor with a smaller prop on overdrive?
The 6 pole motor should handle the torque.ReddyWatts fleet photo
Mean Machine - Feigao 540 14XL, 8s, 100 amp HV esc, X537/3Comment
I was thinking the same thing ReddyWatts. The thing is, how much smaller on the prop can you really go? The stock SV27 runs good with a x440/3, thats the prop I ran and my temps where warm on the motor/esc but not to hot. Well if you use fluid's 80% rule, that means that I could maybe run up to a 50mm prop, tops. Betting something in the x445 range.
The pics below are of how FDM builds them. So I am thinking I am going to leave the gear box in. I have used them before, and I have one now in my XL Cat. it works well.
I am going to gear it 1:1 or as close as I can (have to get some gears at the LHS), find a decent prop.....then maybe play with the overdrive idea some... We'll see how motor temps pan out. The ESC and lipos should be bullet proof with this motor.
The gentleman I purchased it from called me today and said he shipped it UPS 2-day so I should have it friday. I have everything else I need and more to get this boat going. And I have a GPS. So this is gonna be a experiment with the little SV motor......and it's gonna have to happen quick. The next race is oct 7th.Last edited by FE_Chris; 09-19-2007, 05:18 PM.Fast Electric and Fast Ford's / V8 Mustang EnthusiastComment
I would start with an X440 on 1/1.2 overdrive then add more pitch. That will increase your rpm and load by 20%.
I may try this on my next build using dual drive SV motors in a Mean Machine hull on overdrive with one set of batteries and M442/LR props. Hmmmm...............Last edited by ReddyWatts; 09-20-2007, 01:26 AM.ReddyWatts fleet photo
let me ask something, maybe a dumb question, but I wanna make sure. To get a 1:1 ratio, does it matter if I use 2x 80 tooth gears, or 2x 40 tooth gears? I picked up a couple of 81t gears and just got to thinking....Fast Electric and Fast Ford's / V8 Mustang EnthusiastComment
If it will fit, run it. I use some cigarette paper between the gears when I mount the motor for a spacer. Helps you from wearing out the gears and stripping them.ReddyWatts fleet photo
He does not want to remove the trans and wants to start out with 1:1 then later play with different gears.ReddyWatts fleet photo
