Hydra 240 running twin motors?
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3480
    The hydra 240 looks like a perfect setup to run twin motors. It is basically two separate controllers piggy backed. It would provide nearly perfect power distribution for twins.
    Is there any reason one 240 controller cannot be used to run two separate motors? (one from each board)
  • Boatman
    • Jan 2008
    • 796
    Ha! sounds good but just like powering each set of wires separately. It will throw the balance off and blow.
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3480
      I'm certainly not going to try it, but I would like to see someone who has!
      Tell me more about this balance? What does the piggy back pc card do? I'm not familiar with how these card setups work.
      • m4a1usr
        Fast Electric Addict
        • 2038
        Yeah. One real big reason. The back emf coming off each motor is not going to be the same. Might be close but wont be the same. Thats why Castle does not recommend such an application. So rotor timing issues would be the first and biggest reason. Anyone else got their 2 cents?
        John
        Change is the one Constant
        • crabstick
          • Jul 2008
          • 954
          sounds like a recipe for
          Matt.
          FE, Nitro and Gas racing in Auckland
          www.rcboats.co.nz
          • Xfactor
            Banned
            • 861
            You would probably be more sucessful if you were running a sensored design with hall and 3 magnets 120 degree apart lined up with the poles.
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3480
              John
              OK, so the small board does more than I thought. If there's only 1 brain... bad news.
              • Xfactor
                Banned
                • 861
                This kinda falls under the cant we do this thread
                  You can easily run two brushed motors off a single ESC, that is an entirely different case. Running two BL motors off the same ESC sounds great and has been done, it is not recommended by any ESC manufacturer. For low-power applications it might work for awhile, but eventually the ESC will fail.
                  • Xfactor
                    Banned
                    • 861
                    Sensorless desing relies on back emf for sync
                    • mschaffer66
                      • Jan 2010
                      • 335
                      And I guess right now Castle doesn't have any Hydra 240's to replace it with at their service department so it might take a few weeks to get a replacement if you pop it.
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3480
                        I love asking silly questions.
                          Not silly at all. No one is born knowing all this FE stuff.
                          • FighterCat57
                            "The" Fighter Cat
                            • Apr 2010
                            • 3480
                            For sure! The best way to learn is ask questions. Lots of them... and this is the perfect place to ask. Thanks for taking the time to answer, knowledgeable answers make the questions worth asking. =)
                            The next question... could I stack two 240 ESC's and get a 480 ESC? The PC boards appear stackable and if the brain works the cards off of a bus... why not add more boards?
                            ... but why the hell would I need 480 amps? Is there a motor that could use 480 amps? How many cells would I need to power that? Holy hell, like 6 10 cell packs in parallel?
                            Sounds like I could power a Kayak that way. Hmm...
                            • mschaffer66
                              • Jan 2010
                              • 335
                              Full scale RC jetski.... lol
