Hpr06 1st run...
  • vvviivvv
    • May 2009
    • 1079
    Hpr06 1st run...
    Hi, just ran it, wont get on the plain cuts out and prop cavitation any ideas? the prop was a 4517/3 the battery's are approx where the front of the hatch is, that's approx the middle of them... i need help with strut depth etc... i will try a 47/14/2 when they fix the one they sent me but strut depth etc?
    the cut out??? the speedos are 250 amp max and 150 cont but the logger said the max amps drawn i got to was 41?...
    Uk SAW record holder
  • KillerDave
    • 370
    Hi vvviivvv,
    My little twitwin or single motor set up?n HOR32 didn't get on plane and it was all down to the prop's.
    I would start with your stingers being a little above the bottom of the hull but not too much, also check your cog, HPR should be able to help you witth that........ Hang on, Is this a
    HPR C-5009, Riptide48, PaynPak 1/12, Miss Budweiser 1/8 Hydro, Miss Freya (own design 1/8 Hydro), HOR 32, Twin 380 HOR 32, Magin one
