Prop advice
  • nma25
    • Dec 2009
    • 7
    Prop advice
    I Have a 32 in rigger and i am running it on a fieago 10xl on 6s and i have no idea what prop I should buy. I was thinking about buying a coupleso i could size up if i wanted to but have no idea where i should start
  • m4a1usr
    Fast Electric Addict
    • 2038
    Thats running some high rpm's on 6S. I would start with a pretty small dia. prop. Like maybe a 35mm if its the first time out. Thats a small prop but then you should start conservatively. If the temps are fine then move up to a 37 or 38mm and test again.
    What rigger? A fullers?
    John
    Change is the one Constant
      One of our members runs that motor on 6S1P in a sport hydro, he spins an m445 up to an m545. I'd start with the former and bring the boat in after one minute to check for heat. He runs 105 second oval race heats with his and temps are okay in a full-bodied hydro.
      A properly set up rigger should be able to spin a larger prop but it depends on how you drive it - long straights with minimal slowing down are best.
      • nma25
        • Dec 2009
        • 7
        Yea it is an fx-1. I already ordered a 45mm and a 47, but i cant remember the pitch. Illjust have to test it with short runs.
